Question about Thermador Kitchen Ranges
F64 code on lower oven of thermador model cm302
  • Anonymous Mar 22, 2014
    Dubble oven Flashing F64
  • 3 Answers
Go to:
http://www.assuredparts.com/ThermadorRangeFaultCodes.html
F64 Lower oven cooling fan air switch not detected Replace air switch,replace cooling fan,check connections, check P6 on PCB control display.
f64 fault code is an issue with the lower oven cooling fan motor and, or (air) sail switch
Posted on Dec 25, 2008
What does code F 64 mean for my thermador double oven?
F64 will appear if lower oven air switch does not close. If air
switch does not close the mode is cancelled after about 45 sec-
onds.
Sep 23, 2014 | Thermador SC302T Electric Double Oven
Thermador F64 upper oven
f64 is a code for the lower oven cooling fan.
Jan 22, 2014 | Thermador Ovens
Thermador upper oven F 64
f64 for the lower, f34 for the upper cooling fans.
Jan 22, 2014 | Thermador C302U Electric Double Oven
Thermador CM302 f63 error code
overheat situation. check oven sensor and soldered pin points for sensor wires at relay board. Resolder if needed.
Feb 10, 2013 | Thermador C301U Electric Single Oven
CODE F64 WHEN TRYING TO USE THE BOTTOM OVEN.
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Mar 29, 2011 | Thermador C302U Electric Double Oven
I am getting an F64 on my thermador electric double wall oven after a few minutes of preheating my upper oven, and the oven turns off. What des this mean?
Jan 05, 2011 | Thermador SEC302 Electric Double Oven
Error code F64 on lower thermador oven. Works for a minute or so then beeps and F64 is showing,
Nov 12, 2010 | Thermador Ovens
I am getting an F64 error message. what is this trying to tell me?
Welcome to FixYa.
The "F64" code on your model of Thermador double oven indicates the control has detected an error with the airflow for the lower oven ( all lower codes start with "6", upper start with "3" )
This could indicate a faulty blower motor, not coming on at all, or if it does come on and still initiates an F64 error it is likely the sail switch is sticking. It can be removed and cleaned as they do become contaminated with dirt, grease and dust over time.
The sail switch is located at the very bottom of the ovens where the grill is, under the lower door.
( F64 can also be initiated by a failed "K4" relay on the control board, but that is less likely )
It can be accessed by way of removing that grill, however it is something usually best left to an authorized B/S/H/ service provider as it can be quiet involved and is better to pull the unit from the wall.
**Turn off the 40 amp breaker to the oven before attempting any service...safety first**
B/S/H/ is the parent company for Bosch, Thermador, Gaggenau, Siemens.
Let me know if I can assist you further regarding this issue and I`ll try to be available asap.
Good luck.
Thank you for choosing FixYa today, please take a moment to rate the info provided here for you.
macmarkus :)
Aug 03, 2010 | Thermador SEC302 Electric Double Oven
I have a Thermador model CM302 with a built in microwave. The microwave makes all the right noises ... but does not heat the food. What's the problem?
I have the same oven and the same exact problem. The problem is with the magnetron. It needs to be replaced.
Nov 20, 2009 | Thermador Ovens
Kitchen Ranges Logo
683 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
