Hello gator1127,
Well, it depends upon the make of your cabinet. Usually, all you have to do is remove the side panels by undoing the screws at the back of the cabinet. Sometimes the front plate is just fixed into slots with plastic tabs that you can just gently pull out. You may have to unscrew the CD/DVD players first though...Depending upon the make, you may be able to replace the button just by removing one side panel. In any case, remove a panel and take a look, you should be able to figure it out from there ;)
Should you have any further questions, please feel free to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FIXYA rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Just checking to see if your issue has been resolved… If
you find that the solution/answer I provided led you to, or resulted in a fix,
please close the ticket with a FixYa! Rating under my solution. I
post them here.
Cheers!
IrishDruid
Just wanted to inquire if your issue is resolved, or if there is anything
further I can do to assist you…
If you find that the solution/answer I provided led you
to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
rating under my solution. I would be very grateful for your show of appreciation.
post them here.
Cheers!
IrishDruid
P.S. -You can rate this solution with one of
four votes, if you feel your issue is resolved."FixYa!"
- The solution provides great advice on how to solve the problem.
(Positive Rating)"Helpful"
- The solution provides useful leads that helps solve the problem.
(Positive Rating)"Thanks
for Trying" - The solution does not solve the problem but the
effort is appreciated. (Negative Rating)"Inappropriate"
- The solution has absolutely nothing to do with the problem. (Negative
Rating)
If your issue is not still not resolved, do not
assign a rating just yet. Please post back as to what steps you took, results,
etc, and I will try to assist you further as best I can.
IrishDruid
