Question about Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator
Kenmore Er dh
I read about your problem and have the exact some one. i bought the part you suggested online, but i don't know how to replace it. i have the Use & Care Guide that came with the refrigerator, but it doesn't seem to say anything useful in there. can you direct me somewhere else that has directions for replacing the controller assembly?
also, i have the kenmore trio model #795.7731. do you think the same part will work for my fridge also? thank you for your help
  • kjwtrent Apr 12, 2008
    my kenmore is the 22.4 cu.ft. Trio
  • Vadim Pen Jul 04, 2008
    All of a sudden the fridge started to make noise. I disconnected the fan at the back but the noise was still there and it was not coming from a bottom compressor as well.
    The noise is coming from behind the wall of the fridge approximately above the compressor somewhere in the middle of freezer drawer.
    What would that be
  • 15,935 Answers
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
I am getting error code dH.. What is this?
Thank you for contacting fixya.com.
DH means defrost heater and refrigerator computer is not sensing the defrost cycle. It is due to a bad defrost sensor located on the evaporator behind the plastic cover in the back of the freezer compartment. You need to replace that.
Also check this link if it helps:-
Please get back to us if you have further query else please accept the suggestion.
Jun 02, 2011 | Kenmore 73503 Stainless Steel Bottom...
On the door display it says " ER DH " what does
I found this to be quite up your alley... gives you possibilities for DIY repair.
Apr 13, 2011 | Kenmore Elite 44723SS Commercial...
Problems for Refrig. Kenmore Elite
May 03, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator warm, display blank but freezer still works
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*#$^
Feb 21, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Er dh code error on Kenmore elite trio
Jul 11, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Refrigerator error er dh
Sep 21, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
LG Refrigerator Defrost Error ER DH
it the def t-stat, def. thermistor, or def. fuse whatever lg decides to call it this week that is causing your issue
Jun 13, 2008 | Refrigerators
Great advice from medeer, I had the same ER DH error code, and my refrigerator began to warm up. I replaced the defrost thermostat assembly part # 6615JB2005H which is located inside the freezer, on the right side behind the white plastic panel. I accessed it by removing the freezer door, all components inside the freezer, and the tracks mounted on the sides of the freezer. Be careful when removing the white panel because a fan is mounted to the left side of the white panel and plugs into the back left side of the freezer compartment.
Found the green technical data sheets under the refrigerator in a small plastic bag near the front.
My refrigerator is 20 months old, just a few months past the warrentee,
Feb 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 795.7731 Fridge warm;freezer cold - Error er dH
I faced the same problem for Kenmore elite Trio Model # 795.77543600 bottom freezer refrigerator. The issue as pointed out by Medeer on fixya.com, turned out to be the part called component assembly, part number 6615JB2005H. I got this replaced yesterday but for 4 hours I did not notice any cooling... so I thought it did not work.... but then in the morning I notice that the issue has been resolved, the refrigerator is cold and there is no eR dH error message. Thanks to all who shared on this site.
Feb 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator Logo
195 people viewed this question
Top Kenmore Refrigerators Experts
Jim Goldsmith
Jim Goldsmith
Richard Roth
Richard Roth
deton8 von Splosion
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
