Question about Emerson MW8108P Microwave Oven
My MW8108p is flashing and making noises
The Side metal plate is making popping noises and flashing white. I keep expecting Carrie Ann to come flying out of the microwave. Is there something i should do or should I keep it running until her arrival?
  • southrnaccnt Nov 23, 2008
    Mine only did this randomly and very briefly (by the time I walked across the kitchen). It happened so infrequently I wasn't worried, but now, my computer makes a humming ?working? noise and the "working" light comes on. HOWEVER, it does not heat. Did I wait too late? Is there any hope? Time for a trip to the store? The microwave is only 5.5 years old.
  • 525 Answers
Do not use the oven! It sounds like the wave guide cover is burned and this poses a fire hazard should you continue to use it. Have a technician look at it and if this is the problem, it is usually a cheap fix.
Posted on May 23, 2008
MICROWAVE METAL PLATE CRACKED
it is megnatron plate which broke. You can replace that plate yourself . Also can can work without if safely.
Jun 20, 2013 | Hamilton Beach 1.1-cu ft Microwave Oven,...
Mw8108p doesn't light or heat
Depending on the age of it, you're better off properly disposing it and buying a new one.
May 03, 2012 | Emerson MW8108P Microwave Oven
Electrical arching between top metal plate and shell?
i would imagine its a shield but iam not completely sure without a good look
Nov 20, 2011 | GE XL1800 1100 Watts Microwave Oven
My Goldstar MV-1310W microwave has sparks flying from the metal plate that's inside on the top.
Microwave ovens do not work well with exposed metal. IF you place uncoated metal in the oven, sparks will occur.
IF the interior of the oven has the metal exposed, it will cause sparking to occur.
There must be NO exposed metal inside a Microwave oven!
Aug 15, 2011 | Goldstar MV-1310W/B Microwave Oven
A number of days ago we put two plates of food in the microwave to reheat them. There was a snap, crackle, pop noise. We checked to see there was no metal object in the unit....there wasn't ...we know...
Are you sure the plates were Microwave oven safe? Some dishes have metal in the colors of the design. A snap, crackle, pop noise normally means there is metal present in the oven.
Jun 05, 2011 | Microwave Ovens
Microwave mw8115ss the turntable makes a loud grinding noise when it's going around.
replac the drive motor . if its not the supports ( or wheels that it turns on ) ****
Jan 09, 2010 | Emerson MW8108P Microwave Oven
We have white
there is a component called a spatter gard inside the oven at the point where the microwaves enter......if food or other foreign substance gets stuck there, then it will start to burn ...the smell and popping noise is coming from the spatter gard.....to fix it you must remove the spatter gard..replace it if it's burnt and /or sand paper the spot clean and then paint the area with a high temperature paint called mr. touch up......to protect the bare metal from the microwaves.....hope that helps
Nov 27, 2009 | Kenmore 80412 Microwave Oven
GE Spacesaver 1800 XL - rattling sound
Hi jnflanders,
You've probably solved this by now, but I'll answer just in case. That part is called the stirrer motor. You can replace it yourself, as long as you have an offset phillip's head screwdriver handy.
Before you order the replacement part, figure out if your stirrer is driven by a d-shaped or a square shaft. You can tell by taking off the round plate on the inside top wall of the microwave. GE makes stirrer motors for both d-shaped and square shafts, so you'll have to get the right one. Here's the d-shaped motor that fixed this problem with my microwave: http://www.appliancepartspros.com/part_details.aspx?part_id=2024961.
Apr 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
FLASHES INSIDE OF MIRCOWARE AFTER IT IS STARTED AND MAKE NOISE
It could be a magnetron sparks to the open metal inside the m/w cavity or some broken wire on high voltage side. It is not HV transformer (when burn create a lot of smoke and bad smell). Magnetron needs to be replace.
Dec 03, 2008 | Whirlpool GT1195SH Microwave Oven
My microwave is um...sparking kind of...inside
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and held in place by a plastic rivet.
It can be fragile, and the metal edges behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean.
Then you can apply some high-temperature appliance paint, available from places liek Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
For more help from Emerson http://www.emersonradio.com ; Get help using your appliance 1-800-898-9020 ; Get help locating a servicer or parts 1-800-695-0098.
Oct 15, 2007 | Emerson MW8108P Microwave Oven
Emerson MW8108P Microwave Oven Logo
436 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
