Question about Pioneer DEH-P6600 CD Player
The display keeps blinking
Keeps blinking, when i turn it on the display is dark for about15-20 sec. and then the displays gets real bright. any ideas?
  • adamw603 Oct 25, 2008
    it worked! thanks!
  • jocity Nov 19, 2008
    willl my prionner screen will not com on at all i cant see nuthing but the cd plays
Turn the radio off. Press and hold the #5. Then do it with the #6. Turn the radio back on and you should be good.
Posted on Oct 22, 2008
My display is intermittent, bright to dark
go to the settings and turn the power saver OFF
Apr 16, 2015 | Dell Inspiron Computers & Internet
How to keep the radio light on?
The sensor behind the plastic readout window needs to be exposed to a sufficient amount of light to alter the display brightness from dark room mode to bright room mode (dimmed display, bright display). Be sure sufficient light falls on the digital readout display when desiring the display to be at its bright mode setting.
Apr 26, 2014 | Bose Wave Radio Am/fm Awr1-1w Remote...
Lg flatron w2353vp
make sure the 'VGA' lead is plugged in properly. if still dark turn up the brightness on the monitor. if still dark after that, go onto the computer settings and turn up the brightness on the display settings.
Hope this helps!!!
Feb 21, 2014 | Computers & Internet
Display is too Dark to work with but brightness lever up to max.
Apparently the backlight for your display is failing. You'll most likely have to have the top half of the macbook replaced per Apple usual service standards.
Feb 15, 2012 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
The display of my boss bv 9974 is too dark!!
If the display is too dark from the start, that is from the point you get the compaq logo then the issue should be with the LCD panel. if it is dark only in windows you can try increasing the brightness by using the Fn Key and the brightness up option in the keypad.
Feb 07, 2012 | Computers & Internet
Led display shut down when the detector detect an alert
You have the unit in dark mode. Press the Dim/Dark button again to get the unit to full brightness. THe unit has 3 levels of DIM. First the unit is at its full brightness, pressing the dim/dark button will dim the display and the unit functions normally. Press the Dim/Dark button again will futher darken the display but when the unit alarms the display is turned off and remain off during the alert. After the alert is over the unit waits 20 seconds of no alert to turn the display back on.
Mar 09, 2011 | DE-1740 Radar Detector
At start up my viewsonic va1912wb display blinks several times then i can see the picture but it is dark almost unreadable. Today it went darker than yesterday. HELP!
If it is dark due to brightness adjustment, get that adjusted. Usually when you adjust the brightness by pressing the menu button, the menu screen would not be dark. If everything is dark dark dark and you can only see some display but in very pitch darkness, then your monitor is a goner, backlit for the monitor is dead, and your monitor will need to be replaced. You can fix the backlit tubing, however it is risky, and expensive, and would cost less if you bought a replacement.
Jan 30, 2011 | Computers & Internet
I now get the same kind of bright lighting during the darkness as in the daylight
Go to Tools...Settings.....Display
Press Color Mode.... Daytime.... Nighttime... Auto
I use Auto...it will automatically change at darkness
click ok
check your brightness I keep mine at 90%
click back three times to go back to main menu
Sep 25, 2010 | Garmin Nuvi 660 GPS Receiver
How do i get brighter pictures
There are only two options for adjusting the brightness of pictures in this camera, exposure and flash setting.
1. Flash Options: The flash is off by default. To turn it on you must press the button with the crooked down-arrow label between the DISP and MENU buttons, and the flash status will display in the top right-hand corner of the display screen. OFF displays the crooked down-arrow and a circle with a line through it. Press the button once for AUTO, displays the crooked down arrow with an "A" next to it. Press the button once more to force the flash, displays the crooked arrow only in the top right-hand display. Regardless of mode, the display will blink rapidly while the flash is charging and remain solid when it is charged and ready for use. Keep pressing the crooked down-arrow button to scroll continuously through the three OFF/AUTO/ON options.
2. Exposure setting: Press MENU, then the left arrow on the top right-hand four-way button on the camera until the COLOR menu is selected. Scroll down to EXPOSURE and press the MENU button again. You will see EV on the display. Use the up and down arrows to increase or decrease the exposure setting. 0.0 is default, you can go up to +1.5 or down to -1.5. Press MENU to exit when you're done. +1.5 would be the maximum brightness setting.
Oct 13, 2008 | VuPoint DC-M306AT-VP Digital Camera
Need best settings for a Panasonic TH-50PZ85U
As with any display best settings are up to the user.
Some general rules about adjustment of a video display device apply
1. if the display is too bright you would decrease brightness by turning it down
2. if the display is too dark you would increase brightness by turning it up
If a display is too bright it will shorten it's life span so you want to keep the brightness down
Contrast must also be adjusted in the same manor
You should increase color saturation to suit your self
Increasing the color saturation too much will decrease the life of the display and look ugly
so you want to add just enough color to satisfy your taste.
Loch Hiam :-)
Sep 14, 2008 | Panasonic Televison & Video
Pioneer DEH-P6600 CD Player Logo
318 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
