Question about Mitsubishi VS-60607 TV
Mitsubishi VS-60707
My tv is 8 yrs old, when you first turn it on the picture is dim until it warms up then it's fine, I do have red & blue lines at the top and bottom of the screen at all times, and if i switch to ANT B i get a vertical jitter. Any help will be appreciated. Thanks
  • Anonymous Nov 15, 2008
    same hee help
    President:
  • 4,402 Answers
Posted on May 28, 2008
Replacement bulb for mitsubishi VS-60705 rear projection tv
The set does not use a bulb, it is a CRT type set which means it has instead 3 picture tubes, a red,green, and blue.
In order to try to help what is this set doing and not doing?
Dec 18, 2012 | Mitsubishi VS-60707 60" Rear Projection...
Mits big screen vs-60707screen comes on red then turns off 10sec
either a bad red crt or bad transistor on the red crt pcb!
Feb 25, 2009 | Mitsubishi WT-42315 42" TV
Vs 7070 no blueuntilwarm and has dark picture
Might be it is worth the buy a new TV,but it is not worth the money to fix it. It is a serious problem!
solutiondoct
Nov 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi VS-6071 60" Rear Projection TV Problem
can you give me the number of the manufacture of a 60in mitsubishi VS-60707
Oct 25, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi rear projection tv problems
this problem is going to be several bad capacitors on the signal board inside your tv. i suggest calling a technician
Feb 16, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Tv lost color
Your problem most likely is on the signal board is my guess. If your not a technician it would be in your best interest to have him check L2C60 on the signal board.
Nov 19, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi VS-60707 60 in. Rear Projection Television
When it gets better after warm up it can be a capacitor in the 160 Volt high voltage circuit or a cold solder joint. these 2 thinks would be my best guess on this set.
Oct 26, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi 60 in vs-60707
. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Aug 10, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Convergence?
You have a fault on the convergence module. Might be an STK, might be something else but repair is definitely warranted.
Jun 07, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi VS-60607 TV Logo
268 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
