Question about Toshiba Satellite A105 Notebook
How to replace CMOS battery
Having repeating short beeps after laptop is turned on
    Genius:
  • 1,027 Answers
Memory error
if the laptop is running and even boots up and the beeps continue it is the CPU (Overheat, not seated, cache memory error)
Posted on Apr 16, 2008
  • Mark Williams
    Mark Williams Apr 16, 2008
    The post listed changing RTC battery
    LINK
    The RTC battery charges while the unit is on. Constant checksum errors is a symptom of rtc battery failure.
Dead
Hi
THe most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
pls rate as fixya if it helps. thanks
Jul 04, 2008 | Acer Aspire 5100 Notebook
Medion NoteBook :LT 9886 The "Battery
The battery is shot and needs replacing.
Jun 30, 2008 | Medion Computers & Internet
Long beep continuous
here is a list of beep code for Award bios chip, which is the one present on you memory card:
repeated beeps - DRAM error
repeated short beeps - Power error
Repeated high & low beeps - Processor is damaged/Overheated
1 short - System boot successfull
2 short - CMOS setting error
1 long 1 short - DRAM or M/B error
1 long 2 short - Monitor or display card error
1 long 3 short - Keyboard error
1 long 9 short - BIOS ROM error
I don't remember the speed of the repeted beeps for the award bios.
But in your case if this is not a DRAM issue, you might try to check if the beeping remain the same once the cmos battery removed (the flat batterie that looks taken out of a watch).
If so this means that it needs to be replaced.
Oct 20, 2013 | MSI PM8M-V Motherboard
Sony pcv rx550 beep codes?
Hi , here are the codes. listen closely.
Beeps
Error Message
Description
1 long, 2 short Video adapter error Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly. Repeating (endless loop) Memory error Check for improperly seated or missing memory. 1 long, 3 short No video card or bad video RAM Reseat or replace the video card. Repeating High/Low
CPU Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat.
Check the CPU fan or BIOS settings for proper fan speed.
Phoenix BIOS beep codes
Beeps Error Message Description 1-1-2 CPU test failure The CPU is faulty. Replace the CPU. Low 1-1-2 System board select failure Replace the motherboard. 1-1-3 CMOS read/write error The real time clock CMOS is faulty. Replace the CMOS if possible. 2-x-x RAM failure Replace the RAM module if possible. 3-2-4 Keyboard controller failure The keyboard controller has failed. Replace the IC if possible. 3-3-1 CMOS RAM power bad Replace the CMOS battery or CMOS RAM if possible. 3-3-2 CMOS configuration error The CMOS configuration has failed. Restore the configuration or replace the battery if possible. 3-3-4 Video memory failure There is a problem with the video memory. Replace the video adapter if possible. 4-3-1 RAM test failure System RAM addressing circuitry is faulty. Replace the motherboard.
Good Luck
Mark
Sep 17, 2009 | Sony VAIO Digital Studio PCV-RX550 PC...
Iam using lennovo y410 series.my lapton suddenly making some beep sound continuously on running and its not getting turned off. i removed battery and shutted down,i have been running laptop continuously ...
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Feb 22, 2009 | Lenovo 3000 Y410 Notebook
Laptop won't boot up. Only 3 beeps.
listen to the beep heres some information on beep code errors
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Jan 25, 2009 | Toshiba Satellite X200-AA3 Notebook
Spilt a drink
I don't know if I can solve this here. But the beeping noise is your pc trying to tell you what is wrong with it. Somewhere there are pc beep codes. http://www.pcstats.com/articleview.cfm?articleID=1223 If these can't help you just put "computer beep codes" into google. Here they are:
Dec 08, 2008 | Compaq Presario 5000 PC Desktop
No video, monitor and video card are good
There 3 possible problem with your board...
1. Processor
2. Ram
3. Bios
Check one by one
Nov 25, 2008 | Soyo SY-KT333 DRAGON Ultra Motherboard
Toshiba Satellite A105 Notebook Logo
953 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
