Question about Abit A17 Guru Motherboard
Connect a vga card on a used a17 mobo
Just acqiured a used mobo how can i connect a vga card to view to vga monitor?what kind of card
  • Rafael83 Apr 12, 2008
    Please help
    President:
  • 2,351 Answers
Hi Rafae183, yes, you're board, Abit Al7/Al7-G supports AGP8x/4x speeds & voltage of 0.8v/1.5volts only.
Below is the Abit link for you're board. Listed on the right of the page is product Inf. & support Inf. Suggest you add this to you're favorites.
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket%20478&pPRODINFO=Specifications
Suggested any one of these AGP8x speed video cards.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=318&
Remember to check for voltage. You're video card must run at 1.5volts only. Warranty's are important too.
Have more questions, feel free to ask.
Best of luck to you!
Mike
How to vote you're expert.
Enter FixYa.com site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Under the solution given by the expert, choose.
Posted on Apr 12, 2008
After post screen monitor goes into standby and cannot boot from dvd
Not picking up video card, or rather losing communications. Use VGA port if available on you card, and make sure monitor is set to same connection port.
Nov 11, 2012 | Computers & Internet
The spynet watch turns on the but the screen is blank I can hear sounds but can not see the menu screen
When exactly you lost the display?
Just right after turning on the computer?While working in Windows? Or every time you open a program or application?
If problem happened just right after turning on the computer, we have 2 point of failures: Monitor or the VGA CARD/MOBO Onboard.
To test your monitor. While computer and monitor is ON. Unplug the VGA cord at the back or the monitor and check if you will see a box moving across the screen says monitor self test.
If no display replace monitor.
It monitor self test passed. Connect computer to a different monitor and if problem persist then update the video card driver or the motherboard chipset. If all fails then you have to replace your video card or motherboard.
Pls do consider replacing the VGA cord as well.
Hope this helps.
May 27, 2011 | Computers & Internet
The light on monitor stays yellow
If your PC has started HDD flashing and there is power to the monitor this means that the video card has not told the monitor to display, its kind of like in standby you can get this if the onboard VGA is faulty.
If you have another basic VGA card insert this into a spare PCI slot while the PC is off and plug the monitor into this instead if this works your monitor is fine and looks like your VGA on the mobo is trashed, just buy decent 512MB PCI or AGP video card and use this setup instead.
Its also good idea to disable the on board VGA in the BIOS.
LOL
Sep 26, 2009 | Compaq Presario 5000 PC Desktop
Will not let me update driver for VGA connection
Hi there, welcome to fix ya.
Have you tried updating your mobo/chipset drivers?
Tim
Aug 28, 2009 | ASUS LCD Monitor
I have an intel motherboard with a gateway tower and dell monitor. We are getting only slight power to our monitor causing it to lose power after only a couple secondes and the monitor to go orange. I...
It looks like the graphic card is broken on the MB (as far as I can say there is integrated VGA card) or even whole mobo is useless. To test it you need to get some external video card - ISA or PCI based on the specs of this mobo. Connect monitor to external card and see what's there. If it looks pretty much the same way then you can throw away your mobo.
Mar 13, 2009 | Intel Motherboard
EMachine stopped displaying video (card not working, just mobo)
Hi there
I would say it's the graphics card that's failed. You might get the same beeps for faulty card as removed card....
Take it to a shop where they can test a compatible card, before they sell you one or install one for you.
Jan 09, 2009 | E-Machines eMachines Desktop PC
VGA PROBLEM
Your onboard video might not be working. I suggest getting a Video card and installing that. If onboard video is a must have then you can buy a low video card that fits your mobo, then search online for your mobos onboard video driver and then your onboard VGA should work.
Oct 23, 2008 | Asrock 775i65G Motherboard
Monitor not working
sorry friend i ws lill busy so could not rply.
Anyways
  • This is the VGA out: ebc4b94.jpg
  • And this is the connection for VGA comes from monitor: c99e5d1.jpg
  • Now if your VGA - Out is mounted on your motherboard then you have on-board VGA card.
  • means you have PCI VGA card.
Now if you want to use another PCI card just remove the one which you are using and use another one. Use only one PCI card for VGA, need not to use more than PCI VGA card at a time.
Thanks
Iqbal
May 13, 2008 | Computers & Internet
Ati radeon agp card
Hi Rafael83,
There may be afew things that may be wrong. One, the video card may be bad, two the motherboard may be bad, or three your power supply may not have enough wattage to power your video card. Or it coud be all of the above.
Sincerely,
Agent Xiong
Apr 30, 2008 | Vga GeForce4 Ti4200 64MB DVIout AGP Card...
Xerox 17 XL765 LCD monitor Wavy lines but pitcure is good
i had this same prob. For me it wasn't the monitor but the video card and or mobo. I tried monitors on other comps adn worked just fine. Tried comp on 4 monitors and same prob. bought new mobo and problem solved. New prob fixing mobo and or video card
Oct 27, 2007 | Gateway FPD2275W LCD Monitor
Abit A17 Guru Motherboard Logo
69 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
