Question about Sony PlayStation 2 (PS2) Console
One of my games will not play, and need to know how to copy it
One of my games wont play because it was on a basement floor (NOT MY FAULT!!!!!!), and it reads to where it shows playstation2 and no further, so how can i repair it/copy it, to a new disk, and it be playable
My game will not work it works until it starts to load.
Posted on Apr 13, 2008
I live in a three story house my wii is in the basement and my wireless router is on the second floor should my wii pick up a signal...i tried to hook up with netflix and my wii says cant find connection
Hi.
1. Try using it upstairs on the 2nd floor and if it works there you know its a range issue with the router.
To then solve it you could run a cable from the router down to the basement (which is a bit old school but very effective and guarenteed to work) or get a second router or modem and place it in the basement. (for modem you would need a phoneline in the basement)
2. If it doesn't work upstairs, make sure you have the correct connection information for your network and that your network is broadcasting its SSID. If your network is not broadcasting it is what is known as hidden. This means that you will have to enter all the network information manually by following the prompts on the wii console.
Jun 16, 2011 | Nintendo Wii Console
5 minutes playing online keep giving me error message that the disk is dirty. i know it's not i played the same cd to another xbox console it's fine. what should i do or what's the problem...
Hi chrisastig
try to save the game you are playing to the hard drive so as to play from hard drive & not from the disk ! this is assuming you have enuf room on ur hard drive to copy the game to ??
You will still need to put the game in (even when playing from hard drive) but i find if its a game you play a lot its well worth doing as it saves on the disc drive/disc spinning whilst playing :-)
saves on overall usage of the xbox too !
If its ok reading the disc for the first 5 mins of usage it should be ok to copy to the hard drive to play from.
If there is a fault with the disc itself it will tell you when you try to copy it to the hard drive & if this is the case (& its a game you like/play a lot??) then try to borrow a copy just to put on ur hard drive only & use ur damaged disc as the 'required even if playing from hard drive' notification to the xbox that you do own the original copy !
Damaged discs are usually ok for 'playing from hard drive' as the information the xbox requires is very little but enuf for it to allow you to play the game (from the hard drive)
You will find it a lot quieter whilst playing anyway ! i think so !
hope this helps :-)
please remember thumbs up :-)
p.s. refer to ur xbox user manual or drop me a mail if you have any problems doing any of the above ??
Feb 14, 2010 | Microsoft Xbox 360 Console
My ps3 wont play one specific game and no blu ray discs. sometimes that one game will work but more often then not it wont. All my other games work just fine!
Good day, to find the fault, use subtitution method, use the game disk on aonther ps3, to check the ps3, get another copy of the game, either lend from a friend or buy one, at that point you know what is the culprit.
Jan 20, 2010 | Sony Playstation 3 (PS3) Console
My central vac is in the basement, I am getting suction in the basement, but no suction on the main floor and the second floor. How do I know if somehting is blocking it or if there is a hole?
That means that you have a clog in the lines where the basement inlets are connected to. They can be tough to get out, you might need to call a professional.
Jan 10, 2010 | Electrolux Central Vacuum
We have got the new call of duty games yesterday ,
yes it lots of people having problems connecting with modern warfare2 they rushed sum copies
Nov 11, 2009 | Sony Playstation 3 (PS3) Console
Plays dvd's but wont play games, what is the problem?
your hard drive could be full, every game you play, so much of the game is copied to the hard drive.
check your game discs for scratches.
let me know
thx
Aug 02, 2009 | Sony Playstation 3 (PS3) Console
Oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Feb 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
Ps3 horrible problem...
r ur ps2 cd's original or copies coz the ps3 doesn't play copies
abd check ur dvd if it's PAL or NTSC and then check ur ps3 for the same thing
if the ps3 is PAL it only plays PAL dvd's and vice versa
Sep 19, 2008 | Sony Playstation 3 (PS3) Console
Crappy computer
the solution on the cd disc is to remove the cd out then uninstall the all games installed in this cd drive replace cd drive when it comes to uninstalling sim delux is goto where saved games in sim deluxe and save folder to a different location then uninstall then re-install with new cd drive and hunt net for nc patches for games that work if this still doesn't work time for re-install windows from scratch if you have a spare hard drive use it to copy all game saves to it then redo windows and all drivers then all games then place saves back into place where they came from. good luck.
Aug 13, 2007 | Gigabyte G-MAX MA6CU (GB-GMAXMA6CU) PC...
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
