Question about Alps MD 5000 Thermal Printer
CR error light on my MD 5000
At this point, I'm not able to print anymore.
The printer draws the same CR error light very time.
Any suggestions will be very much appreciated.
  • 1 more comment
  • Juanita Bacon Jul 12, 2008
    The printer gears up and prints the Windows logo in a blue color and then the orange error light starts blinking. It will not print anything else.
  • cokekid Jul 30, 2008
    as soon as I power up the printer, the error light comes on, and if I go to the properties and print a test page it tells me that there is a error in the CR motor??
  • fcollingwood
    fcollingwood May 11, 2010
    Some more info?
    Could you give a detailed explanation of what you are doing at the time, what the printer does, and what the status monitor (Bottom left hand corner of you monitor) says?
Hi all : I had been plagued for so long a while sometime ago by the "CR Error" message from my MD1000...please, try to read below what I've sent to Mr. Collingwood on what caused it and the procedure my son took to solve the problem...
http://www.hobbyfanatics.com/index.php?act=Msg&CODE=03&VID=sent&MSID=48744
From another Forums' pages just to make sure you'd see it:
http://ipmsphilippines.proboards32.com/index.cgi?action=pmview&view=2&id=31080
Good luck...Best regards
Posted on Sep 06, 2008
Problem with cr motor message comes up and the printer won't print.
CR errors are tough. You might have a "parts" machine now.
Dec 03, 2010 | Alps MD 5000 Thermal Printer
White ink printing with alps MD 5000
To print white, you need to use the spot color option in the printer properties. The object to be printed must be all black. It seems counter to what you might think, but the spot color mode will print the solid black areas as the selected spot color.
Mar 09, 2010 | Alps MD 5000 Thermal Printer
CR motor error prompts
CR Motor Errors are bad. Check to see if there are any bent or misaligned componenets on the carrier.
Mar 21, 2009 | Alps MD 5000 Thermal Printer
Incomplete print job
Cartridge Changer Errors are series. Did printer work before you installed XP?
Oct 10, 2008 | Alps MD 5000 Thermal Printer
Alps MD 5000
When you moved, did you secure the print head and remove the ink cartrdiges? A Changer Error message is bad. Check the changer for any broken or bent parts.
Sep 06, 2008 | Alps MD 1000 Thermal Printer
ALPS 5000
Cartridge changer error can be bad. Inspect and clean the changer. Try changing the order of the cartridges in the holder. Any effect? With just the black cartridge installed, try printing an internal self print test. Does that work?
Sep 04, 2008 | Alps MD 5000 Thermal Printer
Alps MD 5000
Did you pack the printer correctly before moving? When you got the printer, it would have had a packing piece preventing any carriage movement. If you did not put this in place before packing the printer for the move, you have most likely damaged the printer beyond repair.
May 22, 2008 | Alps MD 5000 Thermal Printer
You need to have the driver installed in order to see what error the printer is reporting.
Jan 30, 2008 | Alps MD 5000 Thermal Printer
PLEASE HELP! Error Light blinks when powered up!
Inyadrms, Did the printer get hit or bumped around while in storage? The motor and alignment errors are bad. If you are mechanically inclined, remove the cover and look for broken parts or missing teeth on the gears. While you have the cover off, give it a good dusting
Nov 17, 2006 | Alps MD 5000 Thermal Printer
Alps MD 5000 Thermal Printer Logo
553 people viewed this question
Top Alps Office Equipment & Supplies Experts
Jesse Walters
Jesse Walters
Samuel Konger
Samuel Konger
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
