Help!!! The door seal magically got twisted after my 15 year old son did a "small" load of towels. Now the machine makes horrible sounds (as if off balance). I am not using it until I can fix it. Please send any tips, tricks, or fix help. I may make the son wash clothes by hand from now on! Just kidding! Thanks,
S.
I can give you advice on how to replace the door seal, but I would also recommend you inspect the shocks when you remove the lower panel under the door. I could be wrong, but I'm not sure if the bellow being twisted will cause the vibration you are talking about. I believe there are four shocks on this model. If the washer was overloaded, it could have potentially damaged one of them as well.
This
advice is for the Kenmore Elite and Whirlpool Duet FRONT LOADER style washing
machines. This is the door bellow replacement. Just follow these steps:
1.
Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm)
where it attaches in the rear of the washer. The panel should slide back, and
then lift off.
3. Remove the operator console by removing the dispenser and the screw(s)
behind it. Take a putty knife and insert it under the console seam right above
the door. If you push in slightly while pulling outwards the panel pops off.
Use care not to pull or damage any of the wiring. You can leave the wires
attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located
behind the rubber seam where it attaches to the door frame. Follow this hoop
around to the bottom of the door opening and locate the wire tension spring.
Gently pry this spring apart and pull the wire hoop from the groove. Pull the
rubber boot from the frame and push it inside towards the wash tub. You will
also have to remove the door boot from the fill tube on the left hand side of
the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is
on the right hand side of the door opening. You can leave the latch in place as
long as you remove the screws and push it inside slightly to remove it from the
front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care
to support the door hinges when loosening. They can bend. Set the door aside in
a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the
bottom edge holding it in place. Sometimes the panel can stick. A slight tap on
either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that
are holding it in place. There should be two at the top and two at the bottom.
Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the
wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube
coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be
instructions that come with the door boot with guide marks to ensure you
align it correctly. Once you have the boot in place, tighten the clamp
enough to where it is snug. DO NOT over-tighten or you may damage the tub and
or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order
of how I explained to disassemble. Make sure you connect the door latch
assembly BEFORE you re-install the outer portion of the door boot. Also, make
sure you install the boot completely over the fill tube. There should be a
ridge on the tube where to stop. Sometimes
the tube is not inserted all way into the boot and water will leak behind it. The
clamp is always difficult to get back in place.
If you cannot get the clamp to go back over the tube, you can live
without it. Some newer models do not
have them installed. Just make sure it is a snug fit where the rubber boot
fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back
over the frame of the door opening ensure you fit it snugly all the way around
the door. Beginning at the top of the
door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the
bottom. As you work your way around the door to the 4 and 8 o'clock positions,
you will need to maintain some constant downward pressure while pulling the
spring apart in order to snap it back into place. It would be advisable to use
a second set of hands to hold the wire hoop in place while doing this as it has
the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and
washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button
under OPTIONS 4 times (has to be the same button, though). This will place the
washer in diagnostics mode. You should hear the door latch lock and
"C00" will be displayed on the console. The washer will run through a
series of tests filling the tub, tumbling, draining, and then a final spin. If
you do not wish to wait for the test to complete you can press CANCEL at any
time. The test checks out everything and takes about 15 minutes. Look for any
leaks.
I hope you find these instructions helpful and good luck to you. Post back if you need further assistance.
Posted on Apr 13, 2008
Aug 29, 2010 | Refrigerators
Jul 12, 2010 | Kenmore 42822 Front Load Washer
Jan 19, 2010 | GE GTS18HCM Top Freezer Refrigerator
Dec 14, 2009 | Refrigerators
Oct 09, 2009 | Kenmore HE2 Plus Front Load Washer
Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
May 05, 2009 | GE DBXR463EDWW Electric Dryer
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Aug 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Oct 30, 2007 | Bosch Classixx WFC 2465 Front Load Washer
Mar 17, 2014 | Whirlpool GHW9400 Front Load Washer
171 people viewed this question
Wonderful solution. I have never worked on an appliance and replaced my door seal, which was ripped half way around, in 45 minutes. Thanks for the easy to follw and concise instructions.
