Question about Fisher 9925 Shelf System
Power problem when you turn the power on it turns itself right back off. Please help
  • Anonymous Jun 04, 2008
    i am having the same trouble it will power up then shut right off
  • peachka66 Oct 08, 2008
    Turn the power button on, and good bye scrolls across and the CD changer starts to spin and then it shuts off.
Did you check the fuses
Posted on Dec 27, 2008
Sub-Zero 650 - Keeps turning itself off. The
HI,
Are you having any fault codes along with this issue? Does the fans and light stop working also? This is unusual, is this the G or O model? I need more information to assist you.
Please let me know.
Sep 08, 2013 | Sub-Zero 650 / O Bottom Freezer...
I turn it on and it turns itself right back off
The Zsus and or the Ysus boards are common failures. You can unplug the Zsus board from the power supply and if the power stays on, I would replace both the Zsus and Ysus boards.
I hope this helps,
Skyassoc
Dec 08, 2010 | Hitachi 42HDM12 42 in. Plasma Television
Printing problem hp D7160 error 0xc18a0001 please help
Hi,problem can be solved .Please check out this link for the Ink System Failure problem.
fixyourownprinter.com/forums/printer/39471
These are from the link above:
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turn it back on. You will have to turn the printer off twice and then it will recalibrate.
Our HP 3310 was having the same ink system failure. Tried everything I could find, and had just about given up when I found this forum. I didn't quite get the reset right the first time, but on the second try it worked. After holding down OK, Cancel, Black and Color buttons while turning it off, I turned it back on, it turned itself off and I turned it back on again, it started off doing the calibration and it took about 5 minutes, but when it was finished I had a working printer again.
Also
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
Hope this works for you. Please let me know.
Oct 28, 2010 | Office Equipment & Supplies
Green power light comes on, the turns right back off. No picture. Please help
I'm not sure what TV model you have. But, thing I can tell you is the most common problem.
Most of the time with flat panel TVs, the power supply for the screen fails. And the TV normally turns itself off to protect other parts in the TV from being damaged. Basically " Protection Mode".
You can try leaving the TV unplugged for 30 minutes so the TV can reset itself; then try again turning it on. If it doesn't work after that, it's time for the TV repair shop.
May 21, 2009 | Sanyo Televison & Video
Samsung dlp HL56A65 turns off and on by itself
It looks power board problem.
You need to get service from Samsung.
Mar 04, 2009 | Samsung DLP HL-P5663W 56" TV
RCA TV quit working
is it back projected if so lamp needs changing if not power supply faulty
Dec 08, 2008 | RCA HD52W58 52" TV
Tv keep turning off
It's the power source.
Sep 30, 2007 | Pioneer SD-P50A3-K TV
Fisher 9925 Shelf System Logo
106 people viewed this question
Top Fisher Audio Players & Recorders Experts
SHARCNET-USA
SHARCNET-USA
Are you a Fisher Audio Player and Recorder Expert? Answer questions, earn points and help others
