Question about Refrigerators
Ice maker on Admiral HMG 62165 side by side
I have an Admiral HMG 62165 21.5 cu. ft. side by side refrigerator/ freezer and the ice maker is not making ice.
The temp is fine in both the fridge & freezer.
The water will still flow through the outside of the freezer door but the icemaker is not making any ice.
Is there something I can do before calling a repair man?
Thanks in advance for your help.
My ice maker works fine, the problem is when the ice cubes melt there is an white mushy like solution that rest in the bottom of my clean glass, I have replaced the ice and water filter about a week ago but the problem is still there, the water does com out clear and no sediment are in the bottom of the glass, can you help diagnose my problem please.
thanks, Ed
Posted on Mar 23, 2010
Check the lever in the ice bin. if it is stuck in the up position it thinks the ice bin is full and will not make ice. Just wiggle it to the down position.
Posted on Apr 23, 2009
My admiral model hmg-64184 is leaking water from the bottom of freezer
It sounds like you have a broken place in the door gasket that is allowing warm air to enter the freezer.
May 29, 2015 | Admiral 26 cu. ft. Side-By-Side...
How do you turn off the ice maker in a 21.6 cu ft HMG 62184?
If there is no switch then unplug the harness.
Jul 23, 2014 | Admiral Refrigerators
What are the dimensions of the kenmore elite 22.4 cu.ft. bottom freezer refrigerator?
26'wide X 19" deep X 21'' front to back. I'll never have a side by side again!
Jul 04, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Icemaker does not eject ice all the way so it freezes up on unit
The model number you provided is not a valid model number. Please verify the model number.
Mar 13, 2013 | Admiral 26 cu. ft. Side-By-Side...
My ice is hollow and my freezer looks like an ice cavern.
Check the fill tube where the water comes into the ice maker. Chances are there is a blockage somewhere and little water is getting to the ice maker and the rest is spraying over into the freezer.
Sep 05, 2012 | Admiral 26 cu. ft. Side-By-Side...
Ice/Water dispenser not working correctly
hi,,
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
Jul 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Problem with fridge ice maker
assuming the freezer is cold enough and that you have a valid water supply hooked up, either the icemaker is bad or the water valve is bad, best idea is to replace both.
Mar 30, 2008 | Admiral 26 cu. ft. Side-By-Side...
Need a water filter for my ice maker
you can go to any appliances parts store and get an in line filter it in stalls in the incoming water line before it screws on the water valves comes with instructions if you get the kit
Jan 14, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral Ice maker water filter, which one?
I have an admiral HMG19149 refrgerator with an ice maker. my problem is that the ice tast horable and cant be used. I looked for a filter to change but can't find it. Please help
Refrigerators Logo
704 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
