Question about Whirlpool Duet GHW9150P Front Load Washer
Error f1 I paused the cycle to turn on the xrinses cycle, and then the washer would not restart. Flasing f1.
    Genius:
  • 1,073 Answers
You have a failed electronic control control will need to be replaced
Posted on Apr 15, 2008
The F! error code keeps coming up when I start my washer
F1 means communication error, the best thing to do is unplug unit for 2 mins and try again
Jan 14, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool washer Model WTW6600SW2. Error F1
My boss's washer has the same problem, located the tech manual inside the washer at the front it was saying to check the pressure hose for any kinks if no kinks found and problem continues replace the motor control board.
Nov 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I hit cancel in the middle of a cycle and now it keeps saying F1
From the maytag website:
To remove the error display, press Power/Cancel or Pause/Cancel twice.
If Power/Cancel or Pause/Cancel does not work:
Unplug washer or disconnect power for one minute.
Plug in washer or reconnect power.
Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, call for service.
Sep 24, 2009 | Maytag EPIC MFW9700S Front Load Washer
F1 error code on Kenmore Oasis He
I think there might be a recall on your washer call to see. I am not for sure that there is a recall but I a m pretty sure there is. So don't quote me on that. the f1 error code usually means that you have a bad board. f1 means that your pressure switch line is failing and this is all in your board. check your owners manual if whirlpool is not going to pay for this repair sometimes there are extended warranties in your manual
May 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Per Sears. To fix the problem. Unplug the washer for at least 10 min then push pause or stop 2 times and this will fix the problem.
Mar 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I am getting an F1 error message on my new Whirlpool Washer
Is this a whirlpool frontloader if so you have a faulty control board it's located under the lid. you can remove with 3 bolts 1/4 " socket . and the board is located on the front right side
Jan 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops with an F1 Code during rinse cycles.
Well I have the same problem the only way I have found that my washer works is that on the soiler level make sure you put that on the heavy. And that should work I know its a pain but thats what I do and my washer washs with out stopping
Dec 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
I get an F1 error code at the start of the wash & at rinse cycle.
Your Central Control Unit is most likely the problem. It is the main board in the machine behind the control panel and they have been failing a lot. This is a major problem with the Whirlpool Cabrio and the Kenmore Oasis machines. You will most likely need to call a service technician. People have also called whirlpool and complained and got them to pay for the part. I suggest you try battling with them. The part is faulty.
Nov 17, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
