Polaroid TDA-03211C 32 in. LCD HDTV Logo
Anonymous Posted on Jun 14, 2010
Have a TDA-03211C Polaroid TV. It doesn't turn on, How do I know that the tv has the power supply broken?
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Jun 14, 2010
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3366058
Points
33650
This is what you need to do:
1) Look to see if the power supply module has any caps with leaking/bulging tops.
2) If you do have any indicator lights on the front panel, then it means the Standby 5vdc power supply section is working for the main logic to operate. Look at the termnials of the power supply that is labeled with STBY5V or something like that. This is a MUST HAVE voltage to get th TV started.
3) When the power button is activated, it will send out turn on signal #1 to the power supply module to turn on the main 5vdc (for the rest of the logic ciruites), 12~16vdc (for sound power amplifiers), and the 24vdc (for the backlight inverter board). Another turn on signal #2 is sent to the Backlight on/off control pin on the inverter board. Signal #3 is for turning on the T-CON board LCD panel.
It uses all these turn on signal so when the TV is in standby/sleep mode it will not consume all these power to save electricity and pass Energy Star compliance.
So now you have some basic ideas how LCD TV works and what is needed to turn on the TV.
Check out those voltages before it is on and after it is on
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net.
Chi Chu
Level 3:
  • Polaroid Master 8,457 Answers
Chi Chu
Polaroid Master
Level 3:
Answers
8457
Questions
0
Helped
2820352
Points
26282
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Testimonial: "thank you . I will try those places"
Tv turns on then powers down
Try doing a factory reset. Here is a link to the manual in case you don't have one. Hope it helps. http://www.manualowl.com/m/Polaroid/TDA-03211C/Manual/230758
1helpful
2answers
2answers
Polaroid TDS-03211C 32in LCD TV/DVD Combo
check the fuse right next to the plug on the set if thats not bad then your power board has bit hte dust
that model has so many differant supplies it is hard to say what diode has gone or wheather it is just a bad puffy capacitor
2answers
LCD screen part number for Polaroid tda-03211c
Replacing the LCD panel in any TV is not a cost efficient choice for the average person. The cost of the LCD panel is usually as much or more than the TV is worth, often times costing as much as a brand new TV. Considering the poor reputation for service that Polaroid had before it went bankrupt, it is best you consider another option since the screen is only one part of what makes the TV. Even if you were to replace the screen, you still would have a TV that was out of warranty without any service support if another part fails.
2answers
If anyone is in need of Polaroid lcd tv parts contact me
Do you have any power supply boards left for a TDA03211C?
1helpful
4answers
Looking to buy a Polaroid TDA-03211C the needs repair
I have a 3 year old TV with the same problem as shema_ross.
2helpful
Screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
1helpful
3answers
Tv doesnot power on
two options _bad backlight inverter or the main board ;eed to be change.
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
