Question about Pantech Duo Smartphone
I need help
How do i set my name on the home screen
Start settings owner information write your name and than click done
Posted on Oct 22, 2008
I need the code list for a Quasar big screen tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Oct 17, 2015 | Quasar SP-3235 32" TV
Cant get internet settings
For most cell phone networks and operators, Internet and messaging settings come pre-installed on your phone. You can then start using the Internet and send messages right away.
To download Internet and messaging settings:
  1. From the Home screen, tap the Application screens icon.
  2. Find and tap Settings > Sony Ericsson >Internet settings > Accept.
To configure Internet settings manually:
  2. Find and tap Settings > Wireless & networks > Mobile networks > Access Point Names.
  3. Press the Menu key.
  4. Tap New APN.
  5. Tap Name and enter the name of the network profile you want to create, then tap OK.
  6. Tap APN and enter the access point name, then tap OK.
  7. Tap and enter all other information required by your network operator.
  8. Press the Menu key and tap Save.
Note: Contact your network operator for detailed information about your network settings.
Dec 02, 2011 | Sony Ericsson Walkman® W995 Cell Phone
HOW DO I GET THE INTERNET USING MY PSP?
You need to connect it to a wireless network, from the home screen go along to settings, down to network settings, choose a mode, (Infrastructure should work fine) New connection, Scan, (here you should see your SSID and signal strenght) choose security type that your wireless network has. enter any security details such as WEP key. Choose Easy for address Setting, choose a connection name. (Home) Save it and then test the connection, if it fails it should show you where it fails along the line.
Hope this helps
May 05, 2011 | Sony PlayStation Portable (PSP) Console
For a Nokia E63 from the home screen you can type the contacts name or part of it and it will show up. For some reason now when i type the name from the home screen it does not show up at all. i might...
From your home screen press any alphabet other than the one linked to a number (eg: W , Q, P) then go to Options > "Contact Search ON" which will turn on this feature.
Hope this helps. Good Luck ~SmokinJoe~
Apr 23, 2011 | Nokia E63 Cell Phone
I NEED HELP CONNECTING MY NINTENDO DSI TO MY HOME WIRELESS INTERNET
You need to make sure that the wireless router in your home has either WEP, WPA, WPA2, or no encryption. If it is set to any other encryption level, the DSi will not be able to connect to the network, no matter what.
To set up the network on the DSi, you need to go into the System Settings from the main screen. Go to page 3 of the settings and tap 'internet', then 'connection settings'. Choose any of the 3 connections, and hit the button next to the one you've chosen.
You should be able to automatically connect by clicking "Search for an Access Point". After the list of access points is generated, choose the one whose name matches the name of your network. If the connection has a little 'lock' symbol next to it, it means it is encrypted. You will need to either enter the network key that is assigned to your router, or remove the encryption from your router (not recommended). After that, save the settings and let the DSi test the connection, and you should be finished.
Mar 20, 2011 | Nintendo DSi Black Console
How two use g p r s
If you need to add a GPRS connection to your phone, obtain the access point name and settings (including username and password if required) from your wireless service provider and add these settings to your phone by following next steps: Press HOME > MENU, and tap on Settings. Tap Wireless controls > Mobile network settings > Access Point Names. On the APNs screen, press MENU and then tap New APN. In the Edit access point screen, enter the APN settings. Tap the APN setting item to edit it. Press MENU and then tap Save to save the settings to your phone. This way you will connect using a GPRS connection.
Feb 14, 2011 | HTC Hero Smartphone
Cingular WAP settings
Hi..i am providing you with the WAP and other settings,but still if you need any help,then please contact Cingular at 866.CINGULAR(866-246-4852)
For CSD (Wireless Internet)
Function Setting
Settings Name: Cingular Wireless Internet
Home Page: http://device:home or http://device.home
Session Mode: Permanent
Connection Security: On
Dial-up Number: 14152441012
Gateway IP Address: 66.209.11.61
Authentication Type: Secure
Dial Type: ISDN (on network)
Analogue (off network)
Login Type: Automatic
User Name: WAP@CINGULAR.COM
(All upper case)
Password: CINGULAR1
(All upper case)
For GPRS (Wireless Internet Express)
Function Setting
Settings Name: Cingular Wireless Internet Express
APN: wap.cingular (lower case)
PDP_Type: IP
User Name: WAP@CINGULARGPRS.COM
(All upper case)
Password: CINGULAR1
(All upper case)
Now to set up MMS (Multimedia Services)
Homepage: http://mmsc.cingular.com
Gateway IP 1: 66.209.11.61
Port 1: 9201
Domain 1: (blank)
Service type 1: WAP
Gateway IP 2: (leave alone)
Port 2: 9201
Domain 2: (blank)
Service type 2: WAP
DNS 1: (leave alone)
DNS 2: (leave alone)
Timeout: 10 minutes
CSD No.1 14152441012
Username 1: WAP@CINGULAR.COM
password: CINGULAR1
Speed(bps): 9600
Line type 1: ISDN
CSD No.2: (blank)
User Name 2: (blank)
Password 2: (blank)
Speed(bps)2: 9600
Line type 2: ISDN
GPRS APN: wap@cingular
Username: WAP@CINGULARGPRS.COM
Password: CINGULAR1
Good luck :-)
Apr 22, 2010 | Computers & Internet
My daughter recieved a leapster 2 from a friend. How do you delete the exhisting names from the sign in screen and replace with new names?
Sorry but no, there is no way to remove a player name from the software. However, right from Leapster's website:
Home (The "Home" button is the first button on the front left side of your Leapster2)
A button
Left arrow
Then, touch the X icon that appears at the bottom of the screen and follow audio instructions.
Note: You can only delete a name when all three name slots are filled.
Works like a charm.
Sep 03, 2009 | Leapster Learning System
I need help setting up my email on my iphone
1) If this is the first email account you're setting up on your iPhone, tap Mail. Otherwise, from the Home screen, tap Settings.
2) On the Settings screen, tap Mail.
3) On the Mail screen, under Accounts, tap Add Account.
4) On the Add Account screen, tap Other.
5) Select POP and then enter your account information using your keypad. Name Enter your name. Address Enter your email address. Description Enter a description of this email address. The description displays in your email account list on your iPhone. 6) Enter your Incoming Mail Server information.
Host Name Enter pop.secureserver.net. User Name Enter your full email address as your user name. Password Enter your password for your email account. 7) Enter your Outgoing Mail Server (SMTP) information.
Host Name Enter smtpout.secureserver.net. If you need to change your port, use one of the following for your outgoing mail server, depending on the port you want to use:
smtpout.secureserver.net:25
smtpout.secureserver.net:80
smtpout.secureserver.net:3535
User Name Enter your full email address as your user name. Password Enter your password for your email account. Note: The user name and password for your outgoing server is the same as the user name and password your entered for the incoming server.
8) If SSL mode is enabled, under Outgoing Mail Server (SMTP), tap Advanced.
9) Set Incoming Uses SSL and Outgoing Uses SSL to OFF.
Jul 16, 2009 | Apple iPhone Smartphone
I need help!!!!!:(
Air-Bank is a service provider? if so you can not change it to your own name.
Jul 26, 2007 | Nokia 6560
Pantech Duo Smartphone Logo
Top Pantech Computers & Internet Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Are you a Pantech Computer and Internet Expert? Answer questions, earn points and help others
