Question about Samsung HCN5527W 55" Rear Projection Television
RED I was wondering if there were any troubleshooting ideas for a red screen. One day the picture color was normal and the next day, everything was RED like it was the TV color and not the cable.
  • 121 Answers
Sounds like you have a shorted red crt or a bad drive transistor in the red circuit
Posted on Apr 13, 2008
Red coloring book picture on the vizio!
Sounds like a main board issue--set has a board that controls all info and communication inside the set===faintly possible are also if this is on only part of the screen other boards but main sounds like your problem---All the digital processing for the set including what is on the screen is found there.
It might be helpful to do some research via Google====one place I like to look for info and parts info is shopjimmy.com===if this set by model number is there they will have a list of the boards and prices also----
Also Google the model number with "problems" to see what is out there.
Jun 02, 2012 | Vizio 42 in. LCD TV
Television is a Tosiba DLP 72HM195
your tv needs a y-load board its like a grafix card as computers have due to overheating the board components are affected this is a manufacturing fault it tends to happen with samsung aswell
Feb 22, 2012 | Toshiba 72HM195 72" HDTV
Images on screen are very red. Tried adjusting everything in the menu but still every thing is like glowing red.
Color balance is labeled "Tint"
Color amount is labeled "Color"
Both are in the "picture" adjustments menu.
Either your tint is swung too far to red, or the color setting is wide open making normally pink faces look sunburned...likely it's a combination of the two; Too much red, and a bit too much color.
Going back to the "default factory setting" in "setup" will also drop all settings to center.
Mar 30, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Color seperation and red drooping line
You have defective Convergence IC's. It's best to have a service company verify and do the repair if you wish. Normally runs about $250.00
Jul 14, 2009 | Zenith R45W46 45" Rear Projection...
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
May 15, 2009 | Toshiba 57H81 57" Rear Projection...
Color adjust
Greetings!
Adjusting the picture tubes is a scary proposition, but since you have already done it...
The easiest way to balance the gray scale is to turn the color all the way down on the set. The next part is easier with two people if the screen controls are on the back of the set. This is the part you saw that has six small knobs on it. There are control for the focus of the red, gree and blue and for the screen level of the red, green and blue. You will want to adjust the screen controls in an effort to get the picture black and white (this is why you turn the color down), hence the term "gray scale". Just make slight adjustments, take your and be patient. It will take some time, but you will get your picture balanced back out in time.
Hope this helps!
Rob
Jan 15, 2009 | Philips 50P8341 50" Rear Projection...
PANASONIC PTK-4077S PROJECTION
You need to adjust screen drives on Red Green Blue tubes ,does all 3 of them light up? Focus/screen control box is in front of TV behind front panel Turn color off then adjust all 3 tubes to where you have a black and white looking picture, now turn color back on.
Dec 27, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Color problem
Good Day, pmusso:
The lamp may be going bad/weak.
You can replce it yourself it's easy; call mit's they send to your home with detailed instructions.
Good Luck, big IRISH.
May 26, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Red lamp issue
the color which you see has problem i think you might be seeing white slanting lines also with this. it mainly due to 1 supply to green video supply 2 loose cuntact in g.video section 3 green tr. defective 4 ckt from ic to green input is defective 5 chroma ic defective if supply is ok. regards
Sep 14, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
Samsung HCN5527W 55" Rear Projection Television Logo
70 people viewed this question
Henry  Thomas
Henry Thomas
