Whether supports DDR?
Whether supports the DDR 2700 2 GB my MOTHERBOARD  MSI 845 UltraC (MS 6566)
BIOS TYPE AMI
BIOS Date January 16th 2003
BIOS OEM A6566IMS V1,5 011603 - V1,5
Chipset Intel 1A30 rev 4
OS XP Pro SP2.0?
    President:
  • 2,351 Answers
Hi valentin122, you're board does not support PC2700 memory.
The link below will take you to you're board,
MSI 845 UltraC (MS 6566). Suggest you add to you're favorites.
http://www.msicomputer.com/product/p_spec.asp?model=845_Ultra-C
There is not a bios upgrade to support PC2700 memory.
Bios link.
http://global.msi.com.tw/index.php?func=downloaddetail&type=bios&maincat_no=1&prod_no=295
You're manual is here.
http://global.msi.com.tw/index.php?func=downloadfile&dno=3466&type=manual
See page 2-5 in you're manual.
The mainboard provides 2 slots for 184-pin, 2.5V unbuffered DDR DIMM with 4 memory banks. You can install PC1600/PC2100 DDR SDRAM modules on the DDR DIMM slots (DDR 1~2).
To operate properly, at least one DIMM must be installed.
Here is a link for you're memory. To reach you max GB, you would need 2 DIMMS.
http://www.computermemoryoutlet.com/Standard_DIMMs-PC2100_(266MHz)_DDR-184^pin_NON_ECC_(Usually_for_desktops)-memory.htm
Have more questions, feel free to ask.
Good Luck!
Mike
How to vote you're expert.
Enter FixYa.com site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Under the solution given by the expert, choose.
Posted on Apr 13, 2008
What is the Front Side Bus speed of MSI MS-7312 ver 1.0 motherboard
MOBOT Motherboard Spec Sheet MSI K9MM MS 7312 Motherboards org
THE LINK ABOVE GIVES THE SPECS
MSI K9MM-V (MS-7312) Spec Sheet Powered by MOBOT 10428.jpg Part Number K9MM-V (MS-7312) Manufacturer MSI Price Check Find Best Price Downloads BIOS
Drivers
Manuals Chipset VIA K8M800 VT8237R+ North Bridge VIA K8M800 Socket Socket AM2 (940) Processor Types Athlon 64X2, Athlon 64FX, Athlon 64 Number of CPUs Front Side Bus 800MHz HyperTransport Bus Link Memory Type DDR Memory Channels Dual Maximum Memory 2GB External Graphics AGP8X IGP VIA UniChrome Pro South Bridge VIA VT8237R+ Audio 6-channel IDE SCSI None SATA 1.5 GB/s RAID LAN Firewire None USB USB 2.0 Expansion Slots BIOS AWARD Form Factor microATX
Jun 05, 2014 | MSI K9MM-V Motherboard
Can i chage my processor pentium 4 to core2duo my motherbourd is(MSI PM8M-V H (MS-7104 v2) thnkz
No, you cannot upgrade to a core 2 duo with that motherboard because it is a socket 478.
Jun 04, 2012 | MSI Computers & Internet
I have a MSI MS-6566 Ultra-C v1 with an Intel 2.6MHz CPU. The board is getting power and the CPU fan is running along with the fan on the AGP video card, but the CMOS will not post. The PSU tests fine. ...
have a problem with v1.5 a6566ims always ask if in start setting bios date month and year, and the second when the computer restarted there was no display on the monitor even though I have changed battere, VGA or memory, whether the BIOS has been damaged? what should i do please help. thanks
Aug 31, 2010 | MSI 845 Ultra-C Motherboard
Upgrade
According to motherboard manual (p. 2-9), it can support upto 2GB of DDR400 RAM int total. You can get the manual from http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=565.
Dec 21, 2009 | MSI K8T Neo-FSR Motherboard
Ram upgrade issue msi 845 pro motherboard
you should check bios for the ram settings, voltage and speed, they will be printed on the package the ram came in.
also, you don't want to mix ram up, they will run at the slowest ones speed.
also, most ram is used in pairs (2 at a time) using the 3, depending on the motherboard will give you errors.
try entering the bios on boot, and set the ram setting properly. you should see something that flashes on boot, like press f8 or del for bios. change your ram settings, save and exit. type back with your motherboard and ram model numbers if this solution did not work.
Jun 25, 2009 | MSI 845 PRO Motherboard
Replacing existing DDR RAM
Well this that you can use PC3200 DDR 1GB then those you mentioned above ... and let me tell you there is only bus speed difference between ..
Jun 23, 2009 | MSI 865P Neo (MS-6742-020) Motherboard
Increasing Memory Ram
According to the memory configurator at www.crucial.com your motherboard has two RAM slots that can handle one gig of PC2700 RAM each.
Look here for more information.
http://www.crucial.com/store/listparts.aspx?model=MS-6390
Aug 28, 2008 | Intel Motherboard
Radeon graphics card and 3rd RAM slot conflict
I thought this board looked familiar to me. I recall some rules for the memory cards. Do all your memory cards meet this requirement:
Supports up to 3GB PC1600/2100/2700/3200* DDR SDRAMs
If you are using DDR 400 you can only use 1 slot.
What kind of memory are you using?
Jul 05, 2008 | MSI KT4V (MS-6712) Motherboard
Computers & Internet Logo
736 people viewed this question
David Payne
David Payne
