Question about Sony FD Trinitron WEGA KV-36XBR800 36" TV
Screen bleeding blue-green along entire length (heighth)left side
Picture starting to "bleed" blue-green along entire left edge.
I've been out of town and just noticed it yesterday and today.
Is this a big problem? Is it something that I can fix? how?
or is indicative of a major/costly problem.
Can you help me please?
    Genius:
  • Sony Master
  • 1,689 Answers
This may be some bad capacitors on the video output board or in along the processing path of the video amp sections. It is also possible that the CRT is causing this.
The set should be properly checked to determine the fault.
Jerry G.
Posted on Apr 19, 2008
Remove purple haze around edges
The set needs to be focussed and reconverged. The red and blue images combined make a magenta/purple image. Adding green makes it white. Depending on the type of TV, if it's a CRT projection TV then there's an electronic focus control for each of the three tubes as well as the mechanical adjustment of the optical lenses. Given the description, then I'd have a look at the electronic focus first. A sudden shift in focus suggests that something in that circuit has given out. This would cause the red and blue images to go soft enough to create a halo around objects on screen.
Sep 12, 2014 | Televison & Video
I have changed the rear spindle on the driver side and the rear brake pads. How do I bleed the brakes, or what do I need to do now to get the brakes to work correctly?
On each wheel cylinder you will find a bleed valve. Open the right rear and have someone step down on the brake, then close the valve. Release the brake and repeat. Do that as many times as necessary 'till you don't get air along with the fluid. Repeat the process at the left rear. Before you begin bleeding, fill the master cylinder and check it frequently while bleeding. don't allow it to run dry or you will need to begin the entire process again. Brake fluid can mar your pai8nt so always cover the master so fluid does not get everywhere.
Mar 05, 2011 | Buick Park Avenue Cars & Trucks
Color is bluing (blue bleeding thru)
you can remove front speaker cover,then remove screws from board,you will see 6 controls,3 are focas(all in a row)3 are screen controls.sets are for red green and blue,blue should be to the rite,turn blue controls until picture gets better.they are labeled screen and focas
Sep 24, 2009 | Sony KP-57WS500 57" Rear Projection...
White dashes across top left of TV screen
That is what I was going yo suggest. You can also adjust the picture size. "Just" will show all of the picture even the distortions on the edges. "Full" will in effect overscan and trim those edges off.
Apr 27, 2009 | Panasonic SC-DT100 System
Kv-36hs20
Have you tried disabling SVM (scan velocity modulation)? Often touted as a "feature" of TVs, it's a way of artificially making a picture appear sharp. Totally unnecessary. When SVM (sometimes called VM) is on, it can lead to some color bleeding around edges.
Mar 24, 2008 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Bleeding blue color upon projection
Yes you can replace the lamp, but service in must including the RGB Panels for the same. that will solve ur problem.
Viren
Nov 24, 2007 | Sony VPL CS1 Multimedia Projector
42" philips plasma flat panel television
same problem anyone know what his is please send me an email. real unhappy!!! this tv cost me $900!!!!! rami7344@bellsouth.net
Oct 22, 2007 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
The picture is only producing the basic colours red green and blue
Can you post a picture of the Tv with the issue stated?
Feb 28, 2007 | JVC AV-24F703 24" TV
Sony FD Trinitron WEGA KV-36XBR800 36" TV Logo
66 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
