Question about Proscan 26LA30Q 26 in. LCD Television
Dvd hook up
How do i hook up my dvd player to my proscan tv
  • Anonymous Apr 22, 2008
    HOOKED UP DVD BUT THERE NO SOUND COMING FROM THE TV
Posted on Dec 03, 2008
This is easy. You should have the s-video or cable? Use them.
Also you will want the video cables that are red/blue/green. Simple to hook and works good.
Posted on Jun 20, 2008
4 Suggested Answers
SOURCE: hooking up dvd player
You have wires hooked properly.
On your remote, hit input button, press down arrow once to AV then press right arrow button.
Then watch a DVD.
It worked for me.
Good Luck
Posted on Feb 02, 2008
  • 4 Answers
SOURCE: proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Posted on Jan 28, 2009
  • 814 Answers
SOURCE: dvd stuck in tv dvd player
According the owners manual you will have to call PROSCAN customer support for help with this problem. The telephone number for customer support is 1-888-977-6722. You can also go to The website and use the customer support there. The website for PROSCAN is www.oncorpus.com. I hope this has helped you with your problem.
Posted on May 21, 2009
Tv and dvd hook up no color on tv
is it a tv with dvd combo?..if so..then opening the tv and cleaning the dvd player may help..if not then the dvd unit is suspect..if its a separate dvd player and your using rgb or component cables..you may have a bad cable/connection
Mar 17, 2014 | Proscan Televison & Video
How do I hook a DVD player up to it
If your Proscan TV has inputs for left and right audio and video, you can plug the DVD player in and select video input using your remote
Sep 28, 2013 | Proscan Televison & Video
How to hook up a dvd on a proscan ps32600 tv
This tv has 2 AV inputs at rear to connect dvd player or any other video source.
Plug RCA video cable in AV Input-1 at rear of tv and select Input-1 source in tv remote to get dvd player playback picture in tv.
Click HERE to download user manual free copy that has details about tv operations.
Hope these info will help you.
Thanks.
Nov 26, 2010 | Proscan PS32600 32" TV
Proscan PS8682P dvd player. It has been over a
so you have two problems: how to connect to (ex: tv),so for this. the cable box has a scart port? if so use a scart/rca adapter available on the market, use on VCR out (Cable Box) and select IN the adapter to IN/OUT switch. and connect to dvd player. The other Scart Port labeled TV connect to TV set with a scart cable. Now u can see tv, and switch automatic to dvd if DVD is on.
The Bad Disc error is a Laser DVD lens defective, needs to be replaced, send to repair.
Dec 28, 2009 | Proscan PS8682P
DVD Hook up to Proscan TV
if using RCA connector cables, connect the left and right audio cables to D and D1, then connect the Video cable to the video connector right above the S Video port.
Jun 20, 2009 | Proscan 32LA30Q Television
PLEASE HELP ME CONNECT MY DVD PLAYER TO MY NEW PROSCAN 32LB30Q.
Use either another HDMI cable (available at your local electronics store) or a component video and left/right audio cable to connect the two pieces together. The connections on the back panel of both pieces should be color coded and clearly marked.
Apr 10, 2009 | Televison & Video
I am trying to hook my DVD player up to it and it is not working?
There are many ways to hook up a dvd player to a tv! Audio/video cables, s-video, and component.
Second you need to make sure the tv has the correct source selected. your tv will say on the back which number source you plugged your dvd into. make sure these are the same!!
Feb 28, 2009 | Proscan 42LA30H 42 in. LCD Television
No signal from my dvd player
Can you tell me how to connect my dvd player to my 42 inch proscan hdtv ? There are no yellow,its blue and there are two rows of the same colors.
Feb 03, 2009 | Proscan 32LA25Q 32 in. LCD TV
Hooking up the dvd player
how do i hook up dvd where do i put the wires in what input
Oct 28, 2007 | Televison & Video
Proscan 26LA30Q 26 in. LCD Television Logo
422 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
