Question about Akai PTH5498 54" Rear Projection HDTV-Ready Television
Convergence on PTH5498
Sir,
I'm sorry I did not mention the Model. Is the answer still that I need the original remote to adjust?
Thanks so much,
Les Furrow
  • lesfurrow Apr 13, 2008
    I will order the remote online. Thanks!
  • 53 Answers
Unless you can find a button on the remote you have that saves the settings, I'm afraid so.
Posted on Apr 13, 2008
Reset conversions
Convergence adjustments are located in almost all sets that have that in the main menu--and are adjusted with the original remote---if try that and will NOT adjust--you have a convergence circuit problem.
A brand and model number (not indicated here) would be needed for more of a answer or help.
SD TECH
Apr 26, 2012 | Televison & Video
Red blue green convergence out of sync how to access control without remote
Sorry but you need the original remote to access the convergence settings. Google your model and I'm sure you'll find a site where you can purchase a new remote.
Oct 07, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Hello, my tv looks 3d
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 12, 2010 | Akai PTH5498 54" Rear Projection...
Red and Yellow blurred picture
I had the same problem this week. I tried the convergence thing but it was impossible to fix. I still needed the repairman. He changed two convergence units ($325, parts and labor). Then the tv was still doing the same thing. We had to adjust the convergence and now everything is perfect. You will need your converter
Mar 01, 2009 | Akai PTH5498 54" Rear Projection...
Location of the convergence circuit board inside the KP46WT510
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Jan 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Color separation Akai model pt4298HD
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jan 06, 2009 | Akai PTH5498 54" Rear Projection...
HELLO . it sound like you need to replace the convergence board or just the IC'S ON THE BOARD. IT WOULD BE CHEPER THAN THE HOLE BOARD. "GOOD LUCK"
Jul 27, 2008 | Akai PTH5498 54" Rear Projection...
Adjustments
On the Akai PT429HD? No, you need the original Samsung, as only it has the button to save convergence settings. I got mine for ten bucks. Without doing a proper convergence your set is kind of wasted, so that ten bucks is worth it. I see the price of this remote has spiked lately, so I'd start with ebay first of all.
If you've tried my convergence procedure on the Akai remote and can find a button that saves the settings (the cursor will blink and then center) then you don't need to buy a Samsung one. The only universal remote that has a chance of doing the job would be more expensive than the real one.
Apr 12, 2008 | Akai PTH5498 54" Rear Projection...
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
64 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
