Question about Motorola Mobility H700 Wireless Headset
Static h700 how do you fix static
  • Moki1 Apr 16, 2008
    H700 worked fine for a few months...now there is so much static it is unuseable.
    Scholar:
  • 65 Answers
Good Afternoon.
Has the headset been dropped, or kept in a hot car? The battery could also be going out too, but unlikely if its only 3 months old. Is the headset near the phone? They do have a 10-20 ft range in a perfect condition. But it works best in my tests only a few feet away. As I roam away from the device, it causes static.
Also, is this everywhere you go, or just certain areas?
The reason I ask, if you are near a Wireless network, it could be conflicting. Bluetooth communicates on a 2.4 ghz band. Wireless Network runs on the following: 2.4, 3.6 and 5 GHz frequency
Try removing the device from you phone, and re-connecting it.
Posted on Jul 27, 2009
I evidently dropped my Motorola H700 Earpiece and lost Mic Cover
as far as I know yu have to buy a new one but if you do find out that you can just buy the mic. please let me know
Dec 08, 2008 | Motorola Mobility H700 Wireless Headset
Motorola h700
Ok here is the answer. There H700 have a small foam windscreen inside over the microphone that over time block the sound. The answer is to carefully open the unit and remove the obstruction and clean residue from the microphone and it will work like new. here is a link to pictures and instructions. http://www.geocities.com/jconkwright/H700fix.html
Apr 07, 2008 | Motorola Mobility H700 Wireless Headset
Static-y h700
Since it is only a week old I would take it back where you bought it and tell them it is full of static and get a new one or different one.
This model is notorious for having static problems. You could also do an RMA with motorola since your unit has a 1 year warranty.
http://direct.motorola.com/hellomoto/nss/Replace_an_accessory.asp
hope that helps!
Jan 29, 2008 | Motorola Mobility H700 Wireless Headset
Motorola h700
If your running an HTC phone (If have an HTC Hermes) it has Windows Mobile 5 or 6 running the software for the phone.
I made a modification to the windows registry settings.
You will first need to download a registry-changing software:
http://www.breaksoft.com/Blog/Utilities/2005/1/Mobile_Registry_Editor.aspx
Then follow these steps to increase your bluetooth output:
To achieve better Stereo sound change the following values, found the the following keys.
I was able to do this in about 5 minutes.
[HKLM/Software/Microsoft/Bluetooth/A2DP/Settings]
Add new dword, Value name=BitPool; Value data=48 (Decimal)
Modify, Value name=UseJointStereo; Value data=0 (Decimal, Originally 1)
For BitPool:
Microsoft suggests the following bitpool values for optimal buffer sizes.
30 - Low audio quality
40 - Medium audio quality
48 - High audio quality
58 - Excellent audio quality
Chose one you like. I think 48 is good enough.
For UseJointStereo: use 0 instead of 1, then you got the real stereo.
If you run into any problems, please contact me.
Jan 29, 2008 | Motorola Mobility H700 Headset
H700
go to www.n1wireless.com get another one of these for about 30 bucks.
if yours has water damge it probably toast water always seems to ruin electronics
Jan 14, 2008 | Motorola Mobility H700 Wireless Headset
Bluetooth h700
if this headset has been exposed to water its probably cheaper to get a new one they are thirty bucks at www.n1wireless.com
Motorola HS850-
almost all of moto bluetooth headset get this problem. i think H680 is much better that HS850 or H700. i'm using RAZR2 V8 and almost all BT headset have static problem. So i end up with korean's and french's BT headset which have much lower static.
Dec 05, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola H700
To put the H700 in pairing mode, have the boom closed and hold down the call button. The light should turn purple, then open the boom. Connect to your phone.
Nov 15, 2007 | Motorola Mobility H700 Wireless Headset
H700 problem with Blackberry 7130
It just so happens that I almost bought this headset, but decided not to after reading some reviews. Apparently when paired with the blackberry, the headset doesn't like to function too well. It has a severe problem with distance. Even clothing in the way of the phone and headset can cause static. I've heard some reviewers say they cannot even have the phone and headset on opposite sides of their body because it perfers to have 'line of sight' with the phone. Do some tests by connecting the headset with the phone while they are very close together, almost touching. Once it's initialized, try to keep your phone in a pocket/on your belt on the same side of your body as the phone. I have not heard why these two products work so terribly together, but the problem does not seem to point to the headset or the blackberry, but the combination of the two.
Dec 07, 2006 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
247 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
