New water pump on a 2002 Kia sportage no fload at top of the radiator hose. Put a water hose in the block and water wood through the top of the radiator. Then you I put the water hose to the top hose on the radiator and run the water through and it would come out the block with the water hose but when you put every thing back. And run the motor no water at the top of the radiator hose why.
Rusty is from running a bad or no mix of coolant. (PH level is off) You may have a water pump that has corroded impellers, and can't move the coolant as well any more. I would start by making sure to flush the engine block again, and make sure you flush water through every possible hose, and where you can get at it.
