Question about SanDisk Sansa e250 MP3 Player
I formatted, but there's still space taken up.
Hi. i formatted my sansa mp3, but a lot of the memory is still taken up. all my songs, pictures, videos, recordings, EVERYTHING are cleared out, but most of the memory space is still taken up. so what should i do?
  • vietgirl14 Apr 13, 2008
    Hi, I have the same problem as well. I took everything off my MP3 but it still says that i barely have any free space. Actually before this, i have no idea what happened to my songs. i had like 400ish songs on there and all of a sudden i turned it on one day and i only have 150ish left. and now even after i deleted all those songs to start over, it still says I only have a bit of space left. How can I fix this?
  • Anonymous Apr 13, 2008
    i cleared all of my songs in my sansa but when i opened it up, it says "REFRESH DATABASE" and it's stucked up its almost 1 week till now.and it's not charging. what should i do?
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
Memory on my mp3 is almost full without any songs on it.
Try this: Connect your MP3 player to your computer. Open "My Computer". You should see your MP3 player connected. Right click on it. Click on FORMAT. This should completely wipe everything on your MP3 player (except for the original necessary files that came on it origianlly). You should then be able to get all of your space back.
Apr 15, 2010 | Insignia Sport MP3 Player
Sansa Fuze deleted itself
slide the power switch to hold and then connect to system,....it must be detected as a removable disk....then format the player....that should fix the issue...if it doesn't you will need to reinstall the firmware....install sansa updater from the disk provided alongwith and use it to repir your player by updating its firmware...
Aug 22, 2009 | SanDisk Sansa Fuze MP3 Player
Use of micro sd card
If the memory card is over 2 GB, the player can not read it because it was only designed to read up to a 2 GB memory card. It is not showing up on your player because it is too big for the player to read. If you get a smaller card, it should woork just fine on your player and you should be able to access it easily.
Apr 05, 2009 | SanDisk Sansa e200 MP3 Player
My mp3 player says that the memory is full but I have no songs
if you are deleted the song using computer interface before, it is still on hidden file. plugin your device to computer and go to your sansa directory,
unhide all hidden file and delete it if you are using windows, but for mac pc, just go to the finder then ampty the trash.
Mar 02, 2009 | SanDisk Sansa e260 MP3 Player
Says i need to free 4mb of space
You need to format the device:
Format
This will format your Sansa c200 player’s internal memory
1) Select Settings from the Main Menu.
2) Select Format
3) Select Yes to format the internal memory or No to cancel.
-Tha Mp3 Doctor
Nov 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
"unknown" songs taking up memory in my sansa e200
Renew music svc sub, convert to Mp3, or update/remove DRM licensing
Nov 25, 2007 | SanDisk Sansa e200 MP3 Player
Songs delete, memory doesnt
Try formatting it....when you right click on the sansa image on ur comp...click format
May 07, 2007 | Acer MF35 MP3 Player
The Songs won't Tranfer To the Sansa Sandisk e200
Make sure the songs are in the correct format. Make sure the songs are not AAC, WAV, streaming, or some other non-supported format
Apr 15, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
24 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
