Hi! I has refill my ink cartridges for canon mp490 printerbut I don't know how to reset it to make it print.i know you may have more idea then me.thanks for your help.thanks
  • 240 Answers
Welcome to the world of Canon. Simply put, the PG-210 CL-211 cartridges have what I like to call "digital fuses" built in. One fuse for "new" and one for "empty". When you install a new Canon cartridge both "digital fuses" are intact. The "new" fuse tells the printer that it is a new genuine Canon cartridge and resets the page counter internal to the printer. With the page counter reset, the printer "blows" the "digital fuse" and that cartridge enters the used state. When the page counter on the printer believes the cartridge to be completely empty it will "blow" the second "digital fuse" and the printer will from then on refuse to recognize it as a valid cartridge. Some claim to have ways around this, but Canon really has won this battle. My Cartridge World store does not refill these cartridges and does not recommend refilling them. Buying original Canon cartridges is what we recommend.
Posted on Jun 14, 2010
2 Suggested Answers
SOURCE:
MacD7
  • 67 Answers
SOURCE: refilled ink cartridges on pixma mp490 ...will not print
I know this is frustrating. I am all for recycling and using refilled ink and laser toner cartridges. However, the manufacturers make most of their money from ink and toner sales. So, from time to time, they will encode or datecode cartridge chips. The only times I've been ale to get around this is by using at least one genuine OEM cartridge to trick the printer. If that does not work, try another et of refills, or you will have to use only OEMs.
Posted on May 02, 2010
Testimonial: "guru u da man. thnx"
Canon mx330 how to change ink cartridges
Use the thumb drill to literally drill a hole into the side of the old cartridge. Make sure to chose a location that's closer to the top of the ink cartridge to avoid over spillage when you add the new ink. Once you have the hole just squeeze in some ink of corresponding color into the hole. Not a huge amount, but enough to get some use out of it before the next refill. I highly recommend covering the hole afterward with a sticker or something so that you don't dry out the cartride. Reinsert the cartridge into the printer and use. (: All set!
*Note: You may have to reset the count on the cartridge to avoid getting messages that the ink need to be changed. From here on in, use your eyes to determine if the cartridge needs a refill (:
Dec 07, 2014 | Apple Nano 69472169 4X130Ml Premium Refill...
I am trying to scan a document, however the black ink is empty. It only shows the error message that I should refill my ink. Shouldn't I still be able to scan documents?
Must be using PG830 or PG40 50?
For Canon, if either color or black cartridge is empty or out of ink, "Scanner" doesn't work.
That's why your scanner is not properly working.
It's all connected... That's Canon.
Are you refill your cartridge by yourself?
Try "ROADINK" inkjet refill kit. No drill or sharp needles are needed.
It's not only easy to refill, you can have quality printing.
Check out my youtube video, will find how easy refill can be done.
Apr 20, 2011 | Canon MP490 InkJet Printer
CANON PIXMA MP490 ERROR CODE IS 5200 AFTER INSTALLING NEW BLK INK..........
canon mp490 error 5200 solution...... turn off printer,then hold reset button(the red 1 circle with triangle in middle) for 5 sec then whilst holding reset button turn power on let go of reset button then push reset button twice whilst still having hold of power button then release power button then push reset button 4 times and then power button twice hope it works it did for me carlos:)
Jul 30, 2010 | Canon PIXMA MP490 Inkjet Photo All-In-One...
Refilled ink cartridges on pixma mp490 ...will not print
May 02, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Hello,i want to ask-how reset canon mp 490 ink cartriges level,or how reset the printer?sorry for my english
I tried pressing the OK button for 6 seconds, while holding it press the red stop button and hold it until the LCD refreshes.
Nov 04, 2009 | Canon Office Equipment & Supplies
Streaky printing
At most cases of printer, especially which have done refill at cartridge, print quality is poor or streaky. Many factors influencing this printed result. To overcome print quality is poor, maybe following tips can usefull to prevent printed pages are missing lines or streaky.
First step is ordinary to be done many people when print quality is streaky that is doing cleaning. To get good printed result, sometime this facility is used more than once.
Use Ink Refill with Quality Nicely
For printer have refilled, sometime the quality of printing is also influenced by ink. If will fill your printer again, use ink which the was quality of nicely. I have tested some refill inks at cartridge which have been ascertained still nicely ( sorry: I do not want to publicize result of this attempt). In the reality result make me surprise, there ink of refill making the printed quality is crummy. To choose ink refill read following tips :
  • See viscosity of ink, every merk of ink refill have difference of viscosity. Don’t use Ink refill too jell. Difference of this viscosity is no measure reference viscosity of ink from factory maker of printer
  • Don’t fear to try some inking merks. Done this, you’d find refill ink fitt with your printer. I now only using one merk of refill ink ?.
  • This suggestion of forum, but I still not yet proved. May believe or not. Good ink aroma of soft usually.
Change Original Cartridge
This is last choice. A lot not like to do this ways, because price of original cartridge still costly. Alternative, you can use compatible cartridge which the was price of cheaper than original cartridge. At newest printer, usually there are two until four cartridge in one printer. And price four same cartridge almost at the price of printer even there are some costlier.
Let me know !
Thanks
Fame !
Apr 02, 2009 | Canon PIXMA MP130 All-In-One InkJet...
I NEED TO KNOW HOW TO REFILL INK FOR A CANON MX310 #41 COLOR.i DON,T KNOW IF YOU PRY THE TOP OFF OR IF THERE ARE SOME REFILL HOLES SOMEWHERE.SHIRL85@EMBARQMAIL.COM
Your printer uses the following cartridges:
canon-pg-30
Black Pigmented
canon-cl-31
Color
canon-pg-40
Black Pigmented
canon-pg-50
Black Pigmented canon-cl-41
Color
canon-cl-51
Color
ou find the refill instructions for your cartridges in the book at the link below:
Download Inkjet Refill Instructions
You can also buy refill kit here: inkjet refill products.
You also need to reset the cartridge after refill, see: Reset Ink levels for canon mx310 - FixYa
Mar 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Ink cartridge
You basically got scammed on that purchase. The important detail they didn't tell you was that the chips need to be reset on these cartridges. By resetting the chip you are telling the printer it has a full cartridge. Once the chip thinks the cartridge is empty it will cease to print. That's why you got the cartridge to print some and then it quit. You don't necessarily have to buy original Canon cartridges, but you do need to make sure you are buying refills with reset chips. I recommend Cartridge World for refills. I would stay away from internet sellers because they pull stuff like this on you and give you terrible ink.
Jul 21, 2008 | Canon PIXMA MP610 InkJet Printer
How to Override Ink Level Gauge When Using Refilled Cartridges
This maybe in the manual under ink tank replacement, most cannons have this, but keep in mind that sometimes the ink feed tubes to the print head get clogged and then the printer will report no ink at all, these cansometimes be cleaned by soaking them in acholol
May 28, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
820 people viewed this question
k24674
Marvin
Marvin
