Question about Electrolux Lux 7000 Bagged Canister Vacuum
Plastic Slides Trying to open Lux 7000 cannister to access cord spool but can't get plastic slides to move even using needle nose pliers. Plse advise.
  • 625 Answers
Use a screwdriver to pry up one end. there's a little nubbie that snaps into the canister, then its just a matter of pulling the strip off.
the back part with the rewind has two snaps on top internally. use a screwdriver to pry the back part down and out both sides and the rewind will come out.
Posted on Apr 21, 2008
How to replace the cord in dyson's dc07
Things You Will Need
  • Dyson DC07 power cord
  • T15 Torx-bit screwdriver
  • Small can
  • Camera or cell phone with camera
  • Flat-head screwdriver, 3/4-inch or smaller
  • Needle-nose pliers
Tips
  • Do detach the black wire that goes to the motor as it does not require removal.
Warnings
  • Do not work on the power cord when it is plugged in.
  • Do not force the plastic-covered connectors from the switch or you could break the male ends. Pull them off firmly but gently to avoid breaking the terminals.
  • Do not apply too much force to the plastic arms that hold the housing in place. The plastic arms are fragile and may break easily.
References
1 - Unwrap the power cord from the Dyson DC07. Detach the handle of the vacuum cleaner by pressing the release button. Pull the handle from the hose. Slide the hose down the wand and push the button at the bottom to release the hose from the machine.
2 - Press the button at the top of the dust bin handle to remove the canister bin assembly from the Dyson DC07.
3 - Lay the machine on with its back with the power switch facing upward. Locate the Torx screw directly beneath the switch actuator. Remove the Torx screw, turning it counterclockwise. Place the screw into a small can so you do not lose it.
4 - Remove the switch box housing held in place by the Torx screw just removed. Carefully pry upward on the two plastic arms that clip the housing in place. Take a picture with your cellphone or camera of the open housing to make it easier to reinstall the wires where they belong in the channels and spaces provided.
5 - Center the needle-nose pliers on the female connectors from the power cord attached to the switch. Apply equal force to pull them from the male ends of the switch. Also detach the two wires that connect together within the housing, identified by the clear plastic connector between them. Depending on your machine\'s manufacture date, the wires might have different colors. For example, they may be white and brown, all white or one could be blue. Disconnect a total of four wires -- two from the switch and the two connected together. Leave the other wires alone.
6 - Trace the electrical cord on the machine until you reach its protective cover where it enters the Dyson DC07. Lift up the cord protector to remove it from the vacuum. The cord protector has slotted sides that fit within the plastic. Slide the cord protector from the power cord.
7 - Remove the plastic covers that protect the female ends on the power-cord wires that connect to the switch. The new power cord does not come with these. Insert the tip of the flat-head screwdriver through the top of the plastic connector with two internal ridges. Lift upward and away to pull the wire free from the connector. Repeat for the other wire. Push the female end into the plastic connector until it snaps into place. Repeat for the other power-cord wire.
8 - Thread the new power cord through the cord protector. If you have trouble pushing the wires through, reach in with the needle-nose pliers to pull both wires through the rubber protector.
9 - Reconnect the two separated wires back together by inserting the male end into the female end of the other wire. Reconnect the two wires from the power cord to the switch. Reinstall the switch housing on the machine. Align the wires in the channels provided to keep them from being pinched or pulled out when you reassemble the housing. Look at the photo you took earlier as a guide, if necessary. Insert the wire that goes to the motor in this channel and the white wires connected together to the left of the switch in the area provided.
10 - Put on the switch housing cover and secure it with the screw you removed earlier. Reassemble the vacuum in the reverse order you dismantled it.
Aug 27, 2014 | Dyson DC-O7 Bagless Upright Cyclonic...
What is the difference between the electrolux lux 7000 and the electrolux lux legacy
different motor,the legacy does not have a filter,but the same bag...one is made of a light metal [legacy] the other a polycarbonate plastic. Chris
Jun 24, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
How to take cordwinder out of aerus 7000 power cord doesnt retract. so how do i get into the canister where the cordwinder is?
Set the vacuum on the table, bench, etc. on it's wheels, remove the bag and leave the compartment lid open. All internal components are accessed by removing the two rubber side bumpers on either side of the vacuum. This is done by sliding a wide blade screwdriver at the back of the bumper in between the bumper and the plastic rear of the vac and tapping forward with a rubber mallot. Just be careful.
After removing the two rubber side bumpers, turn vacuum over on it's back and pull the bottom off but only after pulling about 2 feet of the retractable cord out for clearance. You may then access the cordwinder to replace. I have replacement cordwinders available for you.
Nov 11, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
Where the power cord goes through the metal casing, there is a plastic thing that protects the cord. I can't get the power cord to slide through nor can I seem to get that plastic thing to release or...
That plastic thing is the cord retainer. The cord will not pull out or push in until the strain relief is pulled out. A needle nose or channel lock pliers should be used. Squeeze the strain relief as close to the housing as possible and pull it out. You can then slide the cord further into the strain relief and replace it in same fashion.
Sep 12, 2011 | Filter Queen Majestic Canister Vacuum
Disassebiling the unit body
It is fairly simple to get the unit apart, but putting the unit back together properly does require some mechanical expertise.
The unit is held together by the two side rails or "bumpers". Once these are removed, the unit will split apart in two halves.
  1. Ensure the unit is unplugged.
  2. Open the bag door, and remove the bag.
  3. With the bag door open, peel about one inch or so of the rubber from each of the side rails back
  4. Insert a tiny flat head screwdriver into the T shaped channel the side rail sits in and lightly tap it in about 3/4" or so
  5. Pull the side rail out using a needle nose pliers. Repeat for the other side.
Once you have the side rails removed, your Electrolux 7000 unit is easiest to disassemble and reassemble if laying on its top. Remove the bottom half of the housing first.
Here is a quick video of the disassembly.
I would recommend taking the unit to an Aerus dealer or a local professional repair shop for any major repairs.
Jul 15, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
How can i disassemble my le2100 to replace the power switch?
This procedure works on almost all Electrolux plastic body canister vacuums. Caution: Always be sure that your machine is unplugged from the electrical outlet before servicing.
Remove the hose from the front cover and pull the electric cord out 2 or 3 feet. Remove the paper bag. Place the vacuum upside down on a work bench with some kind of pad underneath. Open the bag door and pull the end of the soft plastic rail cover out slightly (on both sides) to expose the rigid plastic side rails underneath. If you look directly at the side rails from the front you will see that the ‘T’ shaped part of each rail slides into a channel that locks the top and bottom halves of the machine together. The rails have notches or barbs on the last half inch or so which keep the rails from sliding out. You will need to get these notches away from the channel by sliding a narrow flat blade screw driver in between the top of the ‘T’ and the channel. Just tap it in and leave it there while you pull the rails out with a pair of needle nose pliers. Next, take a look at the bag door hinges. They have a square hole in the center through which a small tab from the bag compartment pokes through. Take a larger flat blade screwdriver and carefully pry the edge of the hinge away from the tab. This will release the bottom section (which is really on top now of course).
If you remembered to pull out the two or three feet of cord before you started then you should now have enough slack so that you can lay the bottom section aside.
If you plan to do any electrical work be sure to mark the locations of the wire connections. Electrolux Service Centers are the only source of wiring diagrams and they don’t like to share.
May 16, 2010 | Vacuums
ElectroLex Cannister model C101J Cord won't retract, trying to remove hard plastc side strips. Appears to be 'one-way' lock in 'T' channel - suggestions unlock?
Use a screwdriver to pry on the top or bottom of REAR cover. I t is held by 4 prongs that fit into 4 holes in tabs. It took a little effort to do mine but it came off. From there you can access retractor mechanism.
Jan 09, 2010 | Electrolux Lux 7000 Bagged Canister Vacuum
I have an Electrolux Model G. I have to take the
Wow an old but a goody.Electrolux rewinds of this age are like land mines. Be very cautious.
The G is similar to its cousin the model 89. In the 89 a service tech would remove the housing cover with the cord spool held secure and stationary stationary and the housing laying flat. Sometimes a clothes pin or small clamp on the outside of the cord housing.....
Once inside there would be a spool with the cord would on and that spool had both a flat metal spring half visible below the side of the spool and and an open center bearing race. Only half the spring would be exposed from above and a special clamp tool was used to reach in and clamp the spring before any parts were disturbed. You might get away with a set of long skinny needle nose pliers but you must not kink the spring by doing so. Then if removing the spool, you would invert the rewind over an ice cream pail to drop the loose bearings , or remove them with a magnetic screwdriver tip.
If your spring is damaged you will get one through Aerus Electrolux , originally Electrrolux US.
If your cord has given way and you are exceptionally careful, without removing the spool you can desolder the terminals on the bakelite spool inside, drill out the rivets holding the contact ring and shorten the cord . this is far easier than attempting to install a new cord .The next step would be to resolder the cord and re rivet the spool contact ring with a pop riveter and washers to secure the tabs cut out in the ring.
If you remove the entire cord you will have to clamp the spring so a snot to lose its unwound tension. This is VERY tricky. Best of luck . please post back to advise what happens.If you impatient, don't even consider this one, just find another G for parts and steal the rewind
Sep 19, 2009 | Vacuums
Electrolux model c101jambassador
screw driver and a hammer just hit the plastic ban out no problem it just has a plastic lock..
May 18, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux Lux 7000 retractable power cord
The trim pieces along the sides just pull off seperating the two housings. The back portion where the retract drum is is held by two plastic tangs on top inside. use a screwdriver to pry the ring down to dislodge the tangs. the bottom part will lift off. remove the front part using two screws just below the hinge. the retract has a long coil spring wound around a free spinning hub. there are two "tangs" inside that engage a ratchet-pawl assembly. you'll need to rotate the drum to rewind the spring onto its hub.
Jun 06, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux Lux 7000 Bagged Canister Vacuum Logo
216 people viewed this question
Top Electrolux Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
