Lg ru45nz60 rear projection television goes pink and blue
This television is a pain the picture will lose color and go pink and blue most times and i have tried everything but when I get it back to shop it will not act up but five minutes in customers house it will.Nuts. I am hearing its a common problem can you locate.
  • 4 more comments
  • rvoisey8 Apr 12, 2008
    Its not the convergence it actually loses it color bot not its convergence.Its a strange
    one.It seems to have mind of its own I hear
    it could be from crt board drive chip not sure
    I have tried every time I try to test the tv will not act up ever.I take it back to customer a 100kms away it act up immediately
    I let it run two weeks resolder and checked everything as best i can,right now Im looking for someone that just knows this because it seems to be common fault
    I need someone who is an lg tv technician to answer the problem please
    IThank you but I know a convergence problem
    when I see one this one is a video problem its colors change while convergence stays solid,and this problem is very intermittent,
    if I could grt it to stay I woyuld have solved it by now.I was hoping you straight
    out may have hear of this on ,thanks
    it is wierd when it changes also,thanks I was reaching when I tried this but someone would have to have experience this or have information on it to get it right
  • 19,396 Answers
Change convergence board or convergence ICs, test them.
Posted on Apr 12, 2008
  • 2 more comments
  • Ginko
    Ginko Apr 12, 2008
    I will see if I find the part, and diagrams . You will need to test the ICs first
  • Ginko
    Ginko Apr 12, 2008
    Parts are only available from LG If your tv switches color and display colors bands it has probably a problem with convergence, A service repairman should test the ICs on the convergence board on your tv.
    If it has been serviced before it is possible that the ICs keep blowing because there is a problem in the power coming to the convergence board, or because the convergence board is defective.
    After fixing the convergence problem a convergence setup procedure must be done from service menu.
  • Ginko
    Ginko Apr 12, 2008
    If the color change but there is no deformation, stripes or bands then is the CRT board.
  • Ginko
    Ginko Apr 12, 2008
    If you need advice from more experts you can use the ask me button on any of the experts, you can try finding one who worked on your model before, it is a free service.
My five year old Toshiba 57H84 rear projection TV has a pink tinted screen when you first turn it on, then after it warms up, the colors are all fine but then the picture has evenly spaced blue tinted...
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 30, 2010 | Toshiba 57H84 57" Rear Projection...
My Hitachi 52 inch Projection TV video goes one
hitachi 52' tv...the blue color is off...you can put magic focus on and it still want move the blue back where it needs to be
Sep 10, 2009 | Hitachi 51F500 51" Rear Projection...
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
Aug 07, 2009 | Hitachi 51F59 51" HDTV Projection...
Picture loses all normal color & changes to snowy blues & greens
Not sure what causes it but it can be fixxed by your local repair guy, I just had mine fixxed for under a hundred bucks, he takes the back off and with a tiny screw driver adjust a few screws to near brand new perfect picture.. and it has been good ever since
Dec 01, 2008 | LG RU-52SZ30 52" Rear Projection...
Red Blue and Green?
All colors in a tv are made up of red ,blue and green,,. my projection in the menu has under setup,,just check for it,,its called conversion ,it realines the colors,, you have to do it periodicaly,or sooner if you move a projection tv,, thanks,, .it should have it,,good luck
Oct 05, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Blue color is now green and oranges are pink
Most likely a CRT coolant leak onto signal pcb.Look for wet
evidence........T.
Oct 25, 2007 | Hitachi 53UDX10B 53" Rear Projection...
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Screen turning pink
If the pink overlay goes away gradually, you could have weak picture tubes (CRT's) If the color jumps in after warming up, it could be a bad solder connection. If you haven't had a good picture to watch for a long time, I would be tempted to put the money towards a new HDTV set as those older Mitsubishi Rear Projection TV's had a Lot of bad solder connections in the past, and by fixing one problem another could crop up in the near future.
Apr 12, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Picture Fades
It isn't clear if the picture just loses color or the screen goes blank. If you are just losing color (picture goes to B/W) there is a problem in the color circuit and from your description it could easily be a bad solder connection on the board which decodes the color portion of the picture. If you are capable with a soldering iron and know TV HV safety, unplug the set, and remove the circuit boards and inspect (with a high powered magnifier)and resolder all suspect looking connections on the boards. You could also resolder all the connections which is more work but assures that solder joints are not the problem. If your problem is not solved at this point you are probably going to need a technician to look at it as it could be just about anything and probably would be beyond your expertise. Good luck and be safe.
Jul 12, 2006 | Sony KP-57WS500 57" Rear Projection...
Televison & Video Logo
234 people viewed this question
Top Televison & Video Experts
