Poor wireless connection
I have set up wireless broadband and the signal is very weak how can I improve this?
    Sergeant:
    Champion:
  • 427 Answers
Open the ports to your wireless device because it could be getting a restricted feed from the router.
Posted on Apr 13, 2008
Cant get wifi unless I am a couple of inches from router. All other wifi devices work perfectly. I even downloaded the latest driver directly from Intel and problem still exists.
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home.
Mar 01, 2013 | Samsung 19628 NP300V5A-A0AUS NP300V5AI
Poor signal with WiFi on my zeepad
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
Dec 13, 2012 | Computers & Internet
Hi everyone, I have a D Link DSL 2640U wireless router.I have been facing problems with connection stability for some time...the problem is that I have to keep my laptop switched on, so that I don't loose...
An unstable connection can be caused by any number of things, especially a weak signal.
Try moving the wireless router higher location away from concrete walls and or to a central location.
To improve the wireless connection, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
Dec 28, 2010 | D-Link Computers & Internet
Playstation 3 says ethernet connection
its your wireless signal you must not have any obstruction between the playstation and the wireless router. walls especialy older ones cause interfearance of signals due to concreat or thick cement on the walls or your routers signal is just to weak try a stronger router with long range capabilities those have more watts to transmit then the standard $30-$60 dollar ones
Sep 02, 2009 | ConnectGear Wireless Ethernet, Broadband...
Linksys wireless b router
Weak signal problem can be fixed by firmware update however, if the client computer is too far from the router, it can't be helped. What you need is a wireless range expander. What it does is give you another 100% signal or atleast stronger signal to the spot or area where you have a weak or dead signal.
Jun 29, 2009 | Linksys Wireless-G Broadband Router
Weak or NO signal to MN-500 Wireless Base Station
Have you tried upgrading the firmware - http://www.tomshardware.co.uk/forum/page-7797_17_0.html
Jan 25, 2009 | Microsoft Broadband Networking MN-500...
Range is very poor
You need to change the wireless channel of the router. Access the router's setup page through http://192.168.1.1, no username, password is admin. Go to wireless tab, Select Manual Setup, change the Radio band from auto to Wide Range. Also change the Wireless network name to a different name then click on save settings at the bottom. Power cycle the router, unplug it for about 30 sec then plug it back in.
Jan 19, 2009 | Linksys Wireless-G Broadband Router
Online hook up
hi ive got my ps3 hooked up with a wireless conection so feel free to ask any questions. you need a wireless hub to send out the wireless broadband signal. is your pc set up with a wireless connection to broadband?
Dec 24, 2007 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
443 people viewed this question
David Payne
David Payne
