Lcd base screws
I just got a 52" lcd Samsung and has no screws for the base. What kind of screws should I purchase? is there a specific kind of screw?
  • Anonymous Nov 16, 2008
    I abandoned my wall mount and went to re-attach the base, but the screws are missing. I usually tape screws to parts I save but obviously didn't this time. I can't find a screw that fits! I can't believe they don't identify the screw type in the manual. To the user that bought one at a hardware store......can you tell me the size????
The Samsung 42MF438 specifically, 42MF438B/27 table top base uses 5mm x 16mm 0.8 pitch screws. Flat heads with Phillips or hex socket work the best. They cost me $0.61 each at my hardware store. If you buy it as a part # 313912879931 it will cost you about $6 plus at least $5 in shipping.
Posted on Jan 06, 2013
  • Mark Maier
    Mark Maier Jan 06, 2013
    Whoops ...make that Magnavox, not Samsung
The screws on the 26" Insignia without the dvd appear to be #8 1 1/2" self threading flat head screws. Hope that helps.
Posted on Dec 26, 2008
Went by Future Shop and asked them to show me what kind of screws I needed. The salesperson took one out of a base on display and showed me. I purchased the screws from the hardware store.
Posted on Apr 13, 2008
How to take base stand off
The should from 4 to 6 screws near where the base & tv come together. They are either #2 phillips or torx(t-20 or t-25) screws. Unscrew and the base pulls out straight down.
Jun 27, 2015 | Mitsubishi LT-52144 52 in. LCD HDTV
What size screw does the table top stand take. Lost mine
The size of the screws used for attaching the TV is M6. You can either use M6X12 or M6X16 screws for attaching the TV. You can purchase the cable from any local hardware shops.
Thank you for contacting FixYa.
Jul 17, 2011 | Sony KDL52V5100 52 in. LCD HDTV
How do you assemble the stand to the tv
This is a pretty easy job.U have the four Philip screws that came with the tv base stand wright?U have a Phillip screw driver wright?Just put the base stand into the tv make sure all the screws holes lines up between the tv and the base stand holes.Than just tighten the Phillip screws with the Philip screws driver,than u are done.
Jul 14, 2011 | Samsung LA40A450 40 in. LCD TV
How do I install the base stand?
Just put base stand into a hole of the main LCD tv unit at bottom base hole and make sure all the screws holes lines up.Put in those holes with 4 or more philips screws on those holes and now just used a philip screw driver turn it clockwises to tighten those philip screws for it to hold on to the base stand.
Feb 05, 2011 | Samsung LN46A530 46 in. LCD HDTV
How do you remove the stand on a samsung 19inch lcd tv..
There are 4-6 screws that must be removed. look on the rear of the TV for screws at the base of fairly deep holes. They require a #2 phillips head screw driver. Remove all of the screws and then get a friend to hold the base whild you pull the tv straight up about 6-7 inches. Joe
Mar 29, 2010 | Samsung 933HD 19 in. LCD TV
I'm trying to mount tv on wall, but how is base removed?
there are some screws in the back.remove the screws and the base can be removed
Feb 18, 2010 | Sharp LC52D65U 52 in. LCD TV
How to remove the stand from samsung 860 52"
  1. Spread the comforter out on a flat surface such as the floor.
  2. Step 2 Lay the Samsung flat-screen television face down on the comforter on the floor.
  3. Step 3 Use the magnetized screwdriver to gently unscrew the four to six screws securing the stand to the television.
  4. Step 4 Remove the screws with the magnetized screwdriver. If you do not have a magnetized screwdriver, cover the end of a normal screwdriver with masking tape with the adhesive side out so that it will catch the screw and pull it from the hole.
  5. Step 5 Pull the stand from the back of the television
  6. Step 6 Mount the television to the wall with wall-mounting hardware you can purchase from any home entertainment store.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Nov 15, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Screen stays black
Move all the pictures to the camera memory card from your internal memory. Since you have to open the camera, the pictures will be lost otherwise. Save your pictures. If you do not have a memory card, transfer all the pictures to your computer.
Remove batteries from the camera.
Purchase a replacement LCD screen, specific to a Samsung S860 camera. These replacement screens can usually be purchased directly from Samsung or from a camera resale shop. Auction websites should also carry LCD screens specific for these cameras.
Use the mini screwdriver to remove the four screws from the back of the camera. Be careful with this step since the screws are tiny.
Take the back cover of the camera off carefully. Inside the camera, there is a piece of foam that supports the LCD screen. Do not remove the foam. Set the bottom portion of the camera to the side.
Turn the top portion of the camera so it is facing upward. Notice how there are clips holding the LCD screen in place. Carefully lift these clips up and remove the broken LCD screen. The screen clips are extremely fragile and break easily if they are lifted too quickly. A gentle touch is key.
Place the new screen down gently and replace the clips. Gently dust the screen so fingerprints are removed.
Turn the top portion of the camera down so the screen is pointing down. Place this on top of the foam padding.
Turn the screws carefully. The best way to screw the back of the camera in place is to first screw in one corner, move to the corner that is diagonally across and turn that screw. Repeat for the other two screws.
Replace the batteries. Turn the camera on and see if it is function
Sep 02, 2009 | Samsung S860 Digital Camera
Lcd base screws
they are medal screws, about 1.5 inches long, and they are fine thread
Jan 11, 2009 | Televison & Video
Toshiba 52 inch flatscreen
I have just completed removing tha base from a Toshiba 52 inch HDTV. There are 5 screws in total. Three about 8 inches form the base and another 2 about 4 inches from the base in the arrangement shown below
(X) is a screw
(l) center line
X X X 3 screws 8 inches from base
X l X 2 screws 4 inches from base
______l______ The base
Keep your feet clear as your undoing the last screw..the base slides out vertically downward and weighs about 10-15 pounds so keep your the toes, fingers etc safe. The risk of being sued may explain why Toshiba didn't this publish in the US manual.
Feb 24, 2008 | Televison & Video
Televison & Video Logo
597 people viewed this question
Top Televison & Video Experts
