Question about Sylvania 6419 Combo
Debug menu I lost the remote to this tv so I got a phillips universal. I pressed a button on this remote and it brought up a debug menu I've never seen before. It shows manu values to adjust and mode to run on and off but I can't exit this menu. Any ideas?
    Genius:
  • Sylvania Master
  • 1,689 Answers
Try unplugging the set from the AC mains for at least one minute. This may get the set to dump out of the service menu.
If this does not work, call the Philips tech support.
Jerry G.
Posted on Apr 12, 2008
How to setup phillips universal remote to a panasonic tv
Philips Universal Remote control Instructions
  1. Turn on the device (TV, DVR, etc.) you wish to operate.
  2. Press and hold the SETUP button until the red light indicator remains lit, then release the SETUP button.
  3. Press and release the desired mode button (TV, DVR, etc.).
More items...
Philips Universal Remote control codes for TV, VCR, Set-top Box ...
www.directutor.com/.../philips-sru210327-universal-remote-control-codes-tv-vcr-set-top... How to setup phillips universal remote to panasonic tv Google Search
Nov 29, 2016 | Panasonic Televison & Video
I need the codes for a phillips universal remote to control a toshiba TV.
  1. Manually turn on the tv.
  2. Hold code search button until the red light stays on.
  3. Press and release TV button-the light should blink
  4. Enter one of the following codes:517 419 512 613 719 112 506 111 618 627 437 041 891 802 111 313 715 With a valid code entry, the light should turn off.
  5. Press channel up button. If the tv responds, the code worked.
If some functions (like mute or menu) dont do what they should, try a different code.
Good luck.
Sep 28, 2011 | Televison & Video
Hi Lost instructions. Would like to obtain how to program my Philips Magnavox remote. Don't know if the #2 MP#20C103-1 or the 1-0010 are the model #s. Thanks
Turn TV on, press and hold CODE SEARCH button until light comes on, press TV, the light will blink and remain on, enter the code, the light will go off, press POWER untill TV goes off....hope this was helpful...
Apr 23, 2010 | Philips Magnavox Learning Universal Remote
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
Teknique Jumbo Universal Remote Control Instructions
Pacific TV - Press "SET" and Hold it, press "TV" and release it, then release "SET", then type one of these codes 0676, 0677, 0678 or 0679. After each code try powering off the TV using the remote. One should work. (I think the 2nd one worked for me).
Jul 18, 2008 | Jensen JER-422 Universal Remote Control
Phillips pm3s lost code book:
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
May 31, 2008 | Philips PM3S Remote Control
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
ORION TV 1926A
lost the remote?... try a different universal remote. i have a orion 27" but i think it has a menu button on the front of the set. im at work.. when i get home ill check and repost....if you dont want to buy another universal.. barrow a friends and give it a try... sometimes the manufacture puts updated CODE's for the remote on the website.. might check that as well. good luck.. more to come.
Jan 22, 2008 | Orion1934 19" TV
Sylvania 6419 Combo Logo
102 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
