Question about Whirlpool GEQ9800P Electric Dryer
Whirlpool electric dryer will not heat
  • 1 more comment
  • Anonymous Jan 25, 2009
    My Whirlpool Heavy Duty Model LER6634DQO just stopped providing heat for both heat condition,High and Low. Ran dryer on all drying options with no difference.
  • Anonymous Mar 23, 2014
    not getting any heat
    not geting any heat
  • 1,073 Answers
Check the thermal limit on the side of the heater housing and the blower thermal on the blower housing
the emement limit is at the top of the blower housing and will have 2 red wires going to it
the blower limit will have blue wires going to it
withe the power cord unpluged, remove the wires to these two limits and with a meter on rx 1 ect. read across each of these if you do not get a meter fluctuation , all the way to the right as you check the part os bad
Posted on Apr 12, 2008
  • 49 Answers
Hello. Heating element's probably O.K. In addition to the breaker, there's probably a THERMAL fuse inside the unit. This will go if it get's too hot.
SOME thermal fuses reset themselves, and some don't. It's a safety issue. You'll probably need to "get inside the dryer" (not the drum - but the overall machine) to find it and check it for continuity (with an ohmmeter). There's probably a schematic inside the dryer that'll help you locate it.
I hope this helps.
Dryer has power...nothing electronic gets power
Remove the rear panel and check the dryers thermal limiter fuse, it may be blown due to dirt and lint build up in the cabinet or a shorted heating element or both..
Jul 16, 2012 | Whirlpool WED6400S Electric Dryer
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
I have an electric whirlpool dryer model# wed5300sq0 and it stopped heating. Still operates just no heat. Figured it must be the heating element so I followed your instructions and did a continuity test on...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
Jul 14, 2011 | Dryers
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
Electric dryer won't heat, maybe the heating element but before it stopped heating i cleaned the lint trap and something fell into it and i didn't notice and turned it on and could hear it hiting...
Sounds like you broke the heating element. Go to a local shop and get one. You may have also burnt the timer so after element you may need a new timer as it tells it to put power to it.
Jul 08, 2009 | Whirlpool LER4634J Electric Dryer
I have a whirlpool dryer that has been blowing the breaker, and is not heating up to dry clothes
how long is it run when breaker is blown? element could be blown and shorting to the cabnet. motor could be full of lint
Jun 28, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Gold Electric Dryer.
Hope your sitting down. There is not just heating elements in the dryer there are thermal switches that turn heating elements off & on like your house thermostat clicks off & on. Also there are overheating thermal switches to keep the elements from setting the dryer, clothes on fire. More than likely you overheating thermal switch has tripped, from lent in vent or pinched vent tube or normal failure. Some of these switches can be reset, others replaced. If you can not trouble shoot electrical circuits leave it to repairman. Switch $20.00 to $42.00 Labor service call cheaper to buy cheap new dryer. Could be heating element but most use only one with different inputs for heat. If your getting some heat not likely element.
Mar 08, 2009 | Dryers
Whirlpool Dryer not heating
first check the circuit breaker in the house, turn it off then back on. if that does not do it then let me know so we can go to the next step. Mike
Jul 14, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer does not heat
check the lint hose could be cloged air need to flow through it to dry if stopped up want dry and can cause a fire
Feb 15, 2008 | Whirlpool LER8648P Electric Dryer
Whirlpool GEQ9800P Electric Dryer Logo
774 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
