Question about Dewalt Self-Leveling Line Laser Horizontal&Vertical - DW087K
DW087K HI IVE JUST GOT NEW BATTERIES FOR THE LASER BUT IT DOES NOT SEEM TO WORK IM SURE IVE PUT THE BATTERIES IN PROPERLY ETC CAN YOU HELP?
  • mattyp69 Oct 26, 2008
    i added new battarys and it wont work now ?
    Champion:
  • 313 Answers
Check first the connection male & female if not loose.
if not` have to send unit in state for repair.
Posted on May 28, 2008
Im getting a crank/ no start situation on my 93 chevy astro ext 4.3Ltr v6 and ive never let a vehicle beat me b4 but this one is giving me a sound whoopin - pls help
Easiest way to trouble shoot a crank no start is to spray starting fluid into the air cleaner intake before you crank it. If it fires then dies it is a fuel problem. If it doesn't fire it is a spark problem. If it fires then dies, check the fuel pressure at the engine end of the fuel line. Pressure below spec prevents the injectors from working properly. See shop manual for the proper procedure.
If it doesn't fire put a spark tester at one of the plug wires set to the proper gap to measure the spark voltage being developed by the coil etc. Good luck.
Sep 22, 2015 | Cars & Trucks
DeWalt DW088 wont work wont switch on why
Immediatly go back to your dealer.is not the way for you but if you are have this problem and read this and if you can in your case replace it in between 8 days do not let repair. go for replace thats the way to handle.
Only thing you can do in this cause is to control your batteries on their dc. 1,4 til 1.6 V
Have allways clean battery contacts
Mar 27, 2013 | Dewalt Dw087k Selfleveling Line Laser...
DEWALT LASER LEVEL SELF LEVELING THE LIGHT LASER IS VERY LOW (VERY HARD TO SEE) CAN BE FIXED? THANKS.
This is one of the cheeper lasers and is designed for predominantly indoor use this Dewalt DW087K unit has a visibility range of 14 yards. Although from experience they do drain the batteries quicker than you would think and cause the laser to be hard to see as well. Hope it works for you!!
May 25, 2011 | Dewalt Dw087k Selfleveling Line Laser...
Horizontal line very dull , vertical line normal
if batteries are new then its either a bad connection to diode,cold solder on pcb or simply a blown diode
May 28, 2010 | Dewalt Self-Leveling Line Laser...
Targus Bluetooth Laser Mouse Rechargeable Battery Trouble
check batterys to make sure there placed in mouse properly.try other usb ports.Batterys may be bad from factory.try some other rechargeables in it.if you have a charger for rechargeable batterys place the batterys in that and see if they charge.if they do then your pc is not charging them correctly/
Jun 11, 2009 | Targus Bluetooth Laser Mouse...
Problems with charging
This still could be either if the cord is being moved at the same time. when the laptop is able to turn on, Does everything (programs, software, etc) function properly? If yes, then we can narrow it to the battery or ac adapter.
To find out whether it is the ac adapter or battery, take out the battery, and see if the laptop powers up and stay that way. If it intermittently closes or shuts down, it's most likely the ac adapter.
If it stays powered on, even if you move it, then it's most likely a battery issue.
If you want to be sure before spending some money, go to a friend's, neighbor's or computer store with a with the same manufacturer (dell, toshiba, etc), and borrow their ac adapter to check
Nov 21, 2008 | Computers & Internet
DW087K
was the lens clean mine gets steamy and makes the line bigger
Oct 12, 2008 | Dewalt Self-Leveling Line Laser...
Low Battery
well im not sure because im not an expert but let me tell you ive had a big experience with ipod problems ive had it lock ive had it freeze ive had it not turn on so i tried to chrge but i had to hold down play and the middle button and i even had it sticky form chocolate melt on it but #1 make sure you have it properly put in and make sure its not locked like mine um if it is hold down the play and midddle button till somethign happens like a dark apple shows up if that doesnt work your best hope is to bring it into best buy or something
Apr 26, 2008 | Apple iPod nano
JVC KD-G631
Too much to type.
Manual is here;
http://www.coda.ru/manual/KD-G631(632)_rus.pdf
Page 12 and 13 have your answers.
Best of Luck.
Oct 15, 2007 | Car Audio & Video
Dewalt Self-Leveling Line Laser Horizontal&Vertical - DW087K Logo
517 people viewed this question
Top Dewalt Measuring Tools & Sensors Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Vuk B
Are you a Dewalt Measuring Tool and Sensor Expert? Answer questions, earn points and help others
