Question about SanDisk Sansa e260 MP3 Player
The screan is saying refreash your darabase
It wont move off screan it just say refreash database.
  • rey2 Apr 13, 2008
    when i turn on my mp3 it says that Load main image failed Switch to Recovery mode- and that is all it does it won't let me listen to music or do anything.
  • gupr Apr 15, 2008
    same
  • 8,596 Answers
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Posted on May 23, 2008
Why is my comp screan blue
might be an hardware issue or a faulty driver issue. can you elaborate your problem?
Feb 25, 2012 | Computers & Internet
The screen has flipped and locked but my apps haven't moved so i cant click them. i have to workout where the apps would be if they flipped to the other side
well with the info as i understand it your screan resolution has been changed depending on your operating system you may be able to start up in safe mode and set your screan resolution back to monitor default or plug and play as they say you will need admin password security with most systems to perform this operation , if you are using an old CRT monitor it could be vertical control is out of alignment gone bad inverted
Let me know more details and I may be able to be more specific
Hope i helped rick
May 18, 2011 | Computers & Internet
What does "freeview database empty"
My tv has been working fine and all of a sudden it wont find any channels on channel search and says "database empty" can anyone help??
Mar 08, 2011 | Televison & Video
When i turn on my sansa e270r it says"refresh database" but the bar wont move at all and i cant do anything
Having gone over a month without a response, I assume my suggested reset solved the problem.
Sep 02, 2010 | SanDisk Sansa e270 MP3 Player
Touch screan it doesn't function
have you installed tablet pc edition os ?
Apr 01, 2010 | Gateway M275 Tablet PC
The color is bleeding and the adjust arrows wont
You have a few choices. You can try to fix it yourself or get a shop to fix it.
It is called a convergence problem.
What do you want to do?
SD TECH
Jan 11, 2010 | Mitsubishi WS-65813 65" Rear Projection...
My sansa freezes refreshing database, it will no go any further.
this is kind of a b*****....what u do is only put a 2 or 3 hundred megabytes on the memory card at once.then unplug from computer and let it refresh...if this doesn't work try putting less on memory card...worked for me
Jun 06, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Syncing dont work!!!!
Sounds like the sync button is probably stuck. You should tap it a few times with something pokey like a pin and see if that helps, if not the contact inside broke off and the easiest thing would be to replace it.
Jan 29, 2009 | Microsoft Xbox 360 Controller
Microsoft Access Problem
You could distribute your tables over a number of databases, and link them back into the original database. To do this, you can use the database splitter to get the initial setup, and then manually move some of the tables from the backen-database to a different database, and reling these moved tables into the original database. Another good idea would be to move the backend storage to be SQL Server rather than Access, which would give you a more stable and more scaleable solution.
Aug 21, 2008 | Microsoft Office 97 Professional Edition +...
SanDisk Sansa e260 MP3 Player Logo
20 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
