RIM BlackBerry  Pearl  8100 Logo
Posted on Apr 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blackberry pearl8100 I have a screen on my blackberry that is kind of cloudy do to me spilling alcohol on it when cleaning trackball, it works fine and I can see anything I bring up but background is somewhat cloudy?
Anonymous
Level 2:
  • Expert 113 Answers
  • Posted on Jan 31, 2009
Anonymous
Expert
Level 2:
Answers
113
Questions
0
Helped
167996
Points
120
You can find Video Disassembly Instructions at
www.fonlogix.us
They have New LCD's and Lenses for the cheapest price.
Here is a Coupon code for 10% off at their site
Code: Fixya10
My Blackberry pearl trackball is not doing anything but sometimes a hard reboot helps. Will reloading the software help?
Chances are it's just dirty from use. If you can carefully remove it and clean the contacts with some rubbing alcohol and let it dry, then replace it, it should work just fine.
90% of trackball problems is simple gunk build up
1helpful
6answers
The ball wont roll on my blackberry. Help!
The trackball is easily removed for cleaning by just pulling the trim ring around the trackball off with your fingernail. Remove the trackball and clean with alcohol. Reverse the process to clean.
2helpful
2answers
Cell phone blackberry trackball stopped working!
Use a alcohol swab and gently rub it over the trackball. Rub it and roll the ball.. Eventually this cleaned the ball and it worked perfectly!!!!
2helpful
Need to fix blackberry trackball
When this has happened to me I've used one of those wet wipes or a Q-tip soaked with rubbing alcohol to clean it off. It usually takes a few wipes. Sometimes I've taken it apart and cleaned the trackball with the q-tip when it's gotten really bad.
Here's a link to show you how it's done:
http://www.blackberryforums.com/general-8100-series-discussion-pearl/113889-how-clean-trackball-your-pearl-8100-a.html
1helpful
3answers
Blackberry Curve 8330 trackball
Under screen/keyboard option there is an area for trackball sensitivity both horizontal and vertical...Increase both and you should be fine.
Aug 19, 2009 • Cell Phones
1helpful
Got my trackball a bit wet and now wont work, what should i do?
You might have damaged some circuitry, but can try cleaning the trackball with alcohol and a Q-Tip. You need to roll the ball around with the alcohol-soaked Q-Tip, then let it try. This will have the nice side effect of helping drive off any leftover water, too.
2answers
Tracking ball is limited in movement. I can scroll across, but not down.
Cause:
The sensitivity of the trackball/trackwheel might be less
Faulty Hardware
Resolution:
Increase the sensitivity by following procedure
Option -> Screen and Keyboard -> Horizontal Sensitivity and Vertical Sensitivity to 100
1helpful
2answers
Blackberry trackball wont work
Buy an iPhone, they don't have hokey trackballs.
2answers
Blackberry Pearl
I had the same issue..
cleaned the trackball with some alcohol and a q-tip.. now working fine!
10helpful
10answers
Blackberry Trackball
I know this is a bit wierd but it has worked for me. Just lick it a few times.
Top RIM Computers & Internet Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Alexander
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
