Question about Alpine Car Audio & Video
Alpine 6 cd player in 2001 Lincoln LS Problems
I have a 2001 Lincoln LS and it has an Alpine 6 cd player, AM/FM sterio. I can't get my Cd Player to play, load or eject cds.
  • 5 Answers
SOURCE: 2003 Lincoln LS
i think you will most likely have to replace the factory unit. That problem is very common with cd changers. it's a mechanical issue. is it the cd changer on the stereo itself?
Posted on Oct 18, 2007
  • 132 Answers
SOURCE: 2001 Mustang 6-disk CD player
does it give an error code? usually it just a gear timing problem, will it load discs that are in it?
Posted on Jan 02, 2008
smarthome2
  • 1114 Answers
SOURCE: 6 CD Changer Stuck (Lexus LX 470)
Open the eject door and at the lower right side of the cartridge their should be a small indent that looks like you could poke it with a medium point pen. That's a reset for the changer. If that does not work, you will need to remove the changer from the car, pull off the top, plug the cable back in and hit eject. look for the arm on the backside of the cartridge and give it a nudge. It may just be stuck. Loading mechanisms usually do not fail before the optics or other!. If you need further help, post a comment with any model #'s on the changer and I'll look for info and help some more. Hope this helps.
Posted on Sep 30, 2009
SOURCE: Jammed cd player - 2002 Honda Accord
I have a 2002 honda accord with the 6 disc cd changer. I beleve the cd changer has jamed and have lost power to the CD player. When I press the CD button it wont recognise the player. Any suggestions
Posted on Nov 09, 2009
SOURCE: cd player on 2001 lincoln ls - cd error when i press load button
My father inlaw just purchased a 2001 lincoln, with a six disc changer, Question is he loaded the unit ,and now he wants to eject the cd's and the changer won't open? any suggestions thanks
Posted on Jan 11, 2010
I have a 02 lincoln ls. when i bought the car the radio and cd player woked but after awhile the cd player quite working. shortly after my alternater went out i got the replace and now the entire radio...
Hi Eric, I'm glad to help!
Eric, you'll need to check power and ground at the CD Player Connector. If it has both power and ground then you need a new CD Player. If it doesn't have either power or ground, which ever one it deosn't have you'll need to find out where it gets it power from OR where it gets its ground from and repair it. Hope this helps and have an awesome day Eric.
Feb 20, 2013 | 2001 Lincoln LS
2003 Lincoln LS
that's a mechanical issue, actually...i'm assuming the rest of the cd player is working?
Feb 29, 2008 | Car Audio & Video
2002 Lincoln LS cd player won't work after battery
Try checking all of your fuses. Quite often a fuse blows when batteries or alternators are changed. There should be a fuse box in the engine compartment and another under the dash.
Feb 12, 2012 | Alpine Car Audio & Video
Is the CDA-9827 capable of playing songs from an mp3 player (does it have an input option)?
The Alpine CDA-9827 only has an input connector for an external CD Changer.
You could get an FM Transmitter for your MP3 Player, and play your MP3 Player using your FM Radio in your Stereo.
Here is an excellent MP3 Player FM Transmitter:
http://astore.amazon.com/tps03-20/detail/B000E43GOO
Here is a copy of your Owners Manual.
Jul 24, 2010 | Alpine CDA-9827 CD Player
Cd player will not eject holds 6 cd 2001 ls licoln says cd error
This happens to me as well, usually if you press and hold the eject button all of the cd's will be ejected. A couple of times I had to use another cd to kind of slide underneath the stuck cd to assist with it ejecting while I pressed the eject button.
Feb 24, 2010 | 2001 Lincoln LS
Cd player on 2001 lincoln ls - cd error when i press load button
Jan 06, 2010 | 2001 Lincoln LS
Cd problems
you need a FM transmitter in that way you just time you car radio you a empty frequency and you will be able to play your ipod on you car stereo.
here is a link of some examples
CLICK HERE
Jun 28, 2009 | Alpine CDA-9851 CD Player
2002 lincoln alpine 6 disc focus error
Probably a Sony clone. Have a look at the Pioneer disc player schematics.
May 22, 2017 | Car Audio & Video
2001 MUSTANG CD PLAYER QUESTION
there should be a little pin push button on cd changer (kinda hard to see) that you put a pin into front it releases the cd dock you should be able to get disks out that way the other way
after this is done take your car sterio to a service sterio technition and have your deck cleaned and serviced so that you can enjoy it for a long time
May 08, 2008 | Car Audio & Video
Car Audio & Video Logo
204 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
