Question about HP PSC 1315 All-In-One InkJet Printer
Changing print cartridge
The "check print cartridge" light IS NOT on. However, I would like to put in a new color cartridge. when I open the door to allow access, the printer cartridge DOES NOT slide to the middle. Am I missing something?
    Problem Solver:
  • 17 Answers
For one the printer must be powered on for to replace ink catrige and if it dosent slide then possibily you roller is dirty if it printed before and this just happened then do you get any error ligts on front of the prrinter could be alot
Posted on Apr 14, 2008
How to change the ink cartridge
Follow these instructions when you need to replace print cartridges.
• Everyday printing: Use a black cartridge along with a tri-color cartridge.
• Color photos: Use a photo cartridge along with a tri-color cartridge.
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge towards you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,
store the black print cartridge in the print cartridge protector or an airtight plastic
container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do
not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad
electrical connections.
8. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into
the empty cartridge slot. Make sure you push the print cartridge in firmly until it snaps
into place.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Jun 30, 2011 | HP PhotoSmart C4385 All-in-One Printer
I bought a new ink cartridge, but cannot find my manual. How do you change the cartridge???
Changing an HP Ink Cartridge
  • 1
    Open the lid of the printer. Depending on the model, there will be two cartridges on the right, one for black and one for color.
  • 2
    Find the cartridge that is running low on ink. The black cartridge will be in black, the color cartridge will have a patch of color (usually green) on it.
  • 3
    Pull down on the black clamp that is holding the cartridge in place and slide out the used cartridge.
  • 4
    Open the package of the new ink cartridge. Remove the protective tape and slide the new cartridge into the printer.
  • 5
    Snap the black protective case back into place and close the lid.
  • techbelkin
    Nov 11, 2010 | HP Officejet 5610 All-In-One InkJet...
    My printer is showing an E sign, and flashing lights next to the ink symbols, but I have changed both cartridges
    Issue : One or both Check Print Cartridge lights are blinking. On light Resume light Check Print Cartridge light Paper Type lights On Off Blinking Off Figure 7: Check Print Cartridge light is blinkingc01058982.gif Cause 1
    The print cartridge access door is open.
    Solution 1
    Make sure that the print cartridge access door is completely closed.
    Figure 8: Close the print cartridge access doorc00858057.jpg Cause 2
    The print cartridges are missing or not seated correctly.
    Solution 2
    1. Open the print cartridge access door. Allow the carriage to move to the center of the product.
    2. Make sure that both print cartridges are installed. If one is missing, obtain a compatible print cartridge and install it in the slot. To check the cartridge compatibility for your product, go to HP SureSupply . To identify your cartridge type in a language other than English, click the language link that appears near the globe icon in the top right corner of your browser.
    3. Run a finger along the top of the print cartridges. If any are sticking up, gently press the print cartridge down and forward into the slot until it clicks into place.
    4. Close the print cartridge access door. If a new print cartridge is installed, the product automatically aligns the print cartridges.
    5. Try the print job again.
    Cause 3
    The plastic tape was not removed from the print cartridge.
    Solution 3
    2. Gently press down on each print cartridge to release it and then slide each print cartridge away from the product, out of its slot.
    3. Turn the print cartridge over so that the ink nozzles are facing up and make sure that the plastic tape has been completely removed from the print cartridge. Remove any plastic tape that remains. CAUTION: Do not touch the ink nozzles or the copper-colored electrical contacts on the print cartridge.
    4. Slide each print cartridge into its slot and then gently press the cartridge down and forward until it clicks into place.
    5. Close the print cartridge access door and try the print job again.
    Cause 4
    The print cartridge is not intended for use in this HP All-in-One.
    Solution 4
    3. Make a note of the number on the print cartridge label.
    4. To check the cartridge compatibility for your product, go to HP SureSupply . To identify your cartridge type in a language other than English, click the language link that appears near the globe icon in the top right corner of your browser.
    5. Make sure that each print cartridge is compatible with the product. If both are compatible, reinstall the print cartridges, close the print cartridge access door, and continue with the next solution. If the print cartridges are not compatible with the product, replace them with genuine HP print cartridges that are compatible with the product.
    Cause 5
    The print cartridges might be defective.
    Solution 5
    Replace the print cartridges with genuine HP print cartridges that are compatible with the product.
    NOTE: The printer might be packaged with only a tri-color print cartridge.
    If all of these steps have been completed and the lights continue to blink, continue to the Service the
    Jul 21, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
    Hp 5550 deskjet not printing
    This is typical cartridge problem.Which cartridge changed?This printer can print with the only one cartridge inside it, whatever which.Try this: Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
    If this not help your printer has problem in carriage unit and need repair.
    Nov 04, 2009 | HP DeskJet 5550 InkJet Printer
    NEEDING TO PUT THE COLOR DRUM BACK INTO THE PRINTER. TRYING TO PUT THE COLOR DRUMS BACK INTO THE PRINTER
    To prevent damage to the print cartridge, minimize its exposure to direct light. Cover theprint cartridge with a sheet of paper.
    1.Open the print cartridge door, and remove the old print cartridge. See the recyclinginformation inside the print cartridge box.
    CAUTION
    To prevent damage to the print cartridge, hold the print cartridge at each end.
    2.Remove the new print cartridge from the packaging, and gently rock the print cartridgefrom front to back to distribute the toner evenly inside the cartridge.
    3.Pull the tab until all the tape is removed from the print cartridge. Put the tab in the printcartridge box to return for recycling.
    4.Insert the new print cartridge in the printer, making sure that the print cartridge is inposition. Close the print cartridge door.
    CAUTION
    If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water.
    Hot water sets toner into the fabric
    You can see the pictures of it at: http://www.scribd.com/doc/4212097/hp-laserjet-1020-users-guide-manual
    Jan 14, 2009 | HP LaserJet 1020 Printer
    Changing cartridge on printer
    The Basics manual from HP:
    http://h10032.www1.hp.com/ctg/Manual/c00694908.pdf
    Check out page 17 of the Basics manual for detailed instruction on replacing the cartridges.
    Caution If the HP All-in-One is off when you open the print cartridge door
    to access the print cartridges, the HP All-in-One will not release the
    cartridges for changing. You might damage the HP All-in-One if the print
    cartridges are not docked safely when you try to remove them.
    print cartridge to release it.
    slot on the left.
    from the slot on the right.
    5. Pull the print cartridge toward you out of its slot.
    cartridge, store the black print cartridge in the print cartridge protector or an
    airtight plastic container.
    If you are removing the print cartridge because it is low or out of ink, recycle the
    print cartridge.
    only the black plastic, gently remove the plastic tape by using the pink pull tab.
    Caution Do not touch the copper-colored contacts or ink nozzles.
    Touching these parts can result in clogs, ink failure, and bad electrical
    connections.
    8. Slide the new print cartridge forward into the empty slot. Then gently push on the
    upper part of the print cartridge forward until it clicks into the socket.
    9. Close the print cartridge door.
    If you installed a new print cartridge, the HP All-in-One prints a print cartridge
    alignment sheet.
    Note If you have colored paper loaded in the input tray when you align
    the print cartridges, the alignment will fail. Load unused plain white paper
    into the input tray, and then try the alignment again.
    If the alignment fails again, you might have a defective sensor or print
    cartridge. Contact HP Support. Go to www.hp.com/support. If prompted,
    choose your country/region, and then click Contact HP for information on
    calling for technical support.
    Jan 03, 2009 | Office Equipment & Supplies
    How do I install an ink cartridge? HP photosmart c5280 All in one
    To replace the print cartridges Perform the following steps to replace the print cartridges:
    1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. The HP All-in-One can get damaged if the print cartridges are not docked safely when trying to remove them.
    2. Open the print cartridge door. The print carriage moves to the far right side of the HP All-in-One. Figure 1: Opening the print cartridge door c00956268.gif
    3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. Figure 2: Removing the print cartridge from the slot c00956269.gif 1 - Tri-color print cartridge slot 2 - Black and photo print cartridges slot
    4. Pull the print cartridge toward you out of its slot.
      NOTE: Remove the black print cartridge to install the photo or gray photo print cartridge, and store the black print cartridge in the print cartridge protector or an airtight plastic container.
    5. Remove the new print cartridge from its packaging, and carefully remove the black plastic tape by using the pink pull tab Figure 3: Removing the new print cartridge from its packaging c00956270.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad electrical connections. Figure 4: Do not touch the copper-colored contacts c00956271.gif
    6. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into the empty cartridge slot. Make sure to push the print cartridge firmly until it snaps into place. If installing the tri-color print cartridge, slide it into the left slot. If installing a black, photo, or gray photo print cartridge, slide it into the right slot. Figure 5: Installing the print cartridge c00956272.gif
    7. Close the print cartridge door. Figure 6: Closing the print cartridge door. c00956273.gif HP All-in-One prints a print cartridge alignment page if a new print cartridge is installed.
    8. When prompted, ensure plain white paper is loaded in the input tray, and then press OK .
    9. The HP All-in-One prints a test page, aligns the print head, and calibrates the printer. Recycle or discard the page. A success or failure message appears.
      NOTE: If colored paper is loaded in the input tray when aligning the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support at www.hp.com/support If prompted, choose your country/region, and then click Contact HP technical support.
    10. Press OK to continue.
    May 15, 2008 | HP Office Equipment & Supplies
    After changing cartridge, printer will not print, z645?
    First... check to make sure you removed the yellow tab from the new print cartridge
    put the ink cartridge back into the printer
    click Start
    click Control Panel
    open Printers and Faxes
    click (or double click to open) your printer icon
    click on Printer menu
    click on cancel all documents
    Then try printing again.
    If this does not work, look in the manual that came with the printer and check out the troubleshooting section.
    Dec 18, 2007 | Lexmark Z645 InkJet Photo Printer
    HP PSC 1315 All-In-One InkJet Printer Logo
    63 people viewed this question
    Seeker5211
    Seeker5211
    mukhtar21 shaikh
    mukhtar21 shaikh
