Question about HP OfficeJet 7310 All-In-One InkJet Printer
Cartrige Alignment I have a 7310 that I'm trying to set up. It says there is a paper jam and will not align. There is no paper jam. It will not feed paper. Can you help?
  • 79 Answers
u can try the following steps .
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
after one minute turn on the prnter . it will go into alligment phase > let it finish .
after its done > try to make a copy .
Posted on May 27, 2008
My paper feeding is crooked
check the paper tray, make sure the paper guides are snug up to the edges of the paper. Even a small gap will cause miss alignment of the printing.
May 15, 2016 | HP OfficeJet 7310 All-In-One InkJet...
Have continuous paper jams every time I attempt to print a document.
You have to have paper in the gears or in the feed or the tractor gears. Cheap paper is a usual problem, you can't use cheap paper. I would also do a maint menu on alignment and print feed and that should do it. If there is no paper jammed and you are using good paper (humidity can wreck havoc as well ) you might just need a new printer cause the feed is broke.
Jul 02, 2015 | Epson EPL 5700i Laser Printer
I changed the ink cartrige,it keeps saying alignment cancelled and the copy button keeps flashing - when i open it up the ink cartrige wont slide back out it seems stuck.
The printer needs to be aligned and it wasn't done after changing the catridge so it does not want to continue. Have you tried pushing the flashing copy button to print another alignment page? Do you know how to align the printer?
After changing a cartridge the printer wants to print an alignment page to make sure that it prints correctly. Some printers have you print a page and they auto align themselves. Others cue you to print the alignment page which has a picture or other graphics that are in specific places and then it instructs you to insert the alignment page face down and press "ok". The printer scans the alignment page and configures the print heads to set up by the marks. It uses the alignment page as a map of where the print should be on the paper.
Try unplugging the printer from the power supply and wait about 30 seconds. Then plug it back in and turn it on. The display should say "print alignment page". Choose yes or confirm to continue. Your printer will either print the page and align itself, or print the page and tell you to insert it and continue. Either way follow the prompts and complete the alignment process in order to continue printing as normal.
If you are unable to get the printer to reset and start the alignment procedure over again, please advise and I will help you solve this problem.
Nov 06, 2010 | HP PSC 2210 All-In-One InkJet Printer
HP 7310 Cartrige Belt Repair
The right end is connected with an idle pulley on a spring. If you grab the left end and pull it to the left, the spring will strech. This will help to attach the belt to the carriage motor on the left.
In some printers the spring streching is fixed by screw that have to be loosen first.
If you can't reach the motor's weel on the left, you have to take off some parts first.
Aug 01, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Since installing new ink cartrige every time I turn on the printer it prints an alignment page
This problem is usually caused by one of the colors in the installed cartrige not printing out on the alignment page. You need to have red, blue and yellow working to get a good alignment. Try removing the cartridge, and wiping the print head with a wet paper towel to try to start the ink flowing. You should see three bands of color ink oozing out the bottom. If not, the cartridge is bad and needs replaced again!
Apr 19, 2010 | HP Photosmart C3150 Printer
HP4680 not feeding paper during alignment
Check and clear any piece of paper is on the paper feeder sensor will resolve your problem.
Revert back for more assistance.
Thank you for using Fixya.
Mar 11, 2010 | Office Equipment & Supplies
Not working see bottom
Check your entire feed to make sure there is NO paper jams. Sometimes even the smallest little piece of paper can get jammed up and can e hard to see.
You can also check your manual for diagnostic mode and alignment print page.
May 13, 2009 | Dell 926 All-In-One InkJet Printer
Paper jam on my toshiba 2060 model
Exactly where in the machine does the paper jam??If it jams when you hit the print button, try cleaning the paper feed tires with WD40.spray it on a clean cloth, clean the feed and pickup tires thoroughly and make sure to get ALL of the WD40 off the tires before using the machine.If you take the paper cassette out and look with a flashight you should be able to identify the paper feed tires.
Mar 24, 2009 | Toshiba 2060 Copier
HP OfficeJet 7310
showing paper jam and have checked and don't see any paper
Dec 17, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Document feeder works for printing but not for scanning
Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
Dec 02, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
26 people viewed this question
Ben Johnson
