Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Removing base from tv
How do i remove the base on my 32 lcd westinghouse tv so i can mount it to the wall on a bracket?
  • 2 more comments
  • sparkyjeff Sep 03, 2008
    how di i remove the base fom my westinghouse 32 '' sk-32h240s lcdhdtv
  • Gizmof55 Feb 03, 2009
    Well I have the same problem. I laid it down and removed the 6 perimeter screws and then removed the 3 small screws on each side and nothing happened.I guess I have to call westinghouse 2morrow
  • jbturkus Feb 18, 2009
    how do i remove the base on my 32 lcd westinghouse tv so i can mount it to the wall on a bracket?
    we keep unscrewing it and nothing happened. we dont want to scratch the lower part of the tv and force it. pls help!
  • kuykendall1 Feb 25, 2009
    I have the same problem how do I remove the base. The screw just keeps turning but not loosening.
I researched this problem on the net and found the solution. Someone on one of the posts said the base can be removed by taking out four screws - all from the back of the TV. One screw is the one closest to the power plug, the next screw is beside it, the remaining two screws are the corresponding screws on the opposite side of the base panel (still on the back of the TV). Once these screws are removed the base comes off including the mounting bolt and the rectangular shaped plastic panel. There are no electronics or any components inside the base panel, only the bolt and plastic base which are held on by the four aforementioned screws. It was very easy to remove!
Posted on Feb 25, 2009
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Sep 08, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
How do you remove the base inner bracket parts so that you can mount the TV on to a wall?
What make and model?
Most wall-mountable TVs will have threaded holes in the back for wall-mounting. Most of which you can bolt a bracket to then unscrew a few of the set-screws for the stand and slide the TV off of the stand.
Most TVs have 4 set screws for the stand located near the bottom middle of the TV where the stand inserts into the TV. The screws may be recessed fairly far into the back of the set and may require a long thin screwdriver.
Jan 01, 2010 | Panasonic TX-32LXD1 32 in. LCD Television
How do I remove the stand of the Sony Bravia XBR KDL-V40XBR1 so i can wall-mount the tv?
you have to lay the tv on it's front on something to protect it from being damaged.on the back you'll see where the base joins the bottom of the display, this needs to be unscrewed and a wall bracket screwed in instead.
Nov 26, 2009 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
I want to take off the base of my flat screen tv.
lay tv down on a flat soft surface remove 4 philips screws on back on either side of signal brd inputs base will pull out of bottom
Oct 15, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Is this TV wall mountable?
Just mounted this TV this past weekend...Used Peerless flat panel wall mount bought on Ebay for $39.99 free shipping...Remove the stand by removing the 4 small screws on the back of the tv where the stand connects...then slide the stand off from the bottom...VOILA
Jul 22, 2008 | Sylvania LC320SS8 32 in. LCD Television
Remove base from TV
Remove 4 screws holding the vertical metal bracket in place. These are located just above the bottom of the rear centre of the TV. The bracket will then slide out.
You might find it easier to remove the footplate first. Simply remove all screws from the bottom of the base. The metal plate and the plastic shield will then detach.
May 27, 2008 | Televison & Video
Swivel Base for a 42LC2D
Hi there is normally a set of 4 to 6 screws that hold the base to the tv set that you remove , you can then possibly use the same screws to attach the wall bracket to the back of the tv before mounting on the wall
hope this helps
cheers John
Dec 25, 2007 | LG 42LC2D 42 in. LCD HDTV
The stand on the bottom
There are a number of small silver phillips head screws atteching the base to the back of the set. Remove these and the base will come off. I would suggest that you replace the screws into the back of the set so they won't be lost. I assume you have purchased the proper mounting bracket. If you shop at Wal Mart, they carry two sizes. The 32" will require the largest size. This info applies to what I purchased, which was the 32" LCD flat panel wall mountable unit. I hope I have been some help.....timitot2
Aug 23, 2007 | iLO 3200 32 in. LCD Television
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
2,974 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
