Question about Mitsubishi VS-45607 45" Rear Projection Television
VS50703 Mitsubishi projection 1998
The color is off (green tint) I trie everything sith color with no solution so I opened the front panel and found the blue lamp is not on. The base has light in it as the green and red do but the actual blue light is not illuminating blue.
Is it burnt out or is there another problem. The tv never gets used even though it is 10-years ole. It is in our basement family room which never gets used.
thank you.Ron Rogers
    New Friend:
  • 83 Answers
Yes u need to buy a new or used blue picture tube for it,, mark where the other is mounted and carefully replace it ,, or get a tech to do it
Posted on May 11, 2008
Yellow tint on projection mitsubishi sl4u
The polarized glass for the Green LCD panel has gone bad, and require to be replaced.
Oct 05, 2015 | Mitsubishi Sl4u Colorview 3 Lcd Projector...
Green tint on picture. Cant adjust with tint or color from menu
My rear projection was doing the same thing. I have a mitsubishi and went into the video/audio set up. When I clicked on video it brought up brightness, tint, color, etc... Not sure if yours is set up the same.
Jan 18, 2011 | Zenith E44W46LCD 44" Rear Projection...
My hitachi 43fdx20b has a pink tint to it. I have noticed that if i move the tint slider one way or the other it will turn the screen green, but now it doesn't. Does this have something to do with my...
My 43fdx20b had a pink tint to it also. The picture was clear otherwise. I found, on mine, I needed to adjust the Red Screen control. It was located behind the front panel. I removed the two screws on either side of the front panel and was able to remove the panel. Then I adjusted the Red Screen control. I found that if I tuned in an old Black and white movie I could adjust the color fairly accurately. Good Luck.
Jan 02, 2010 | Hitachi 43FDX20B 43" Rear Projection...
No blue just red and green tint
adjust the blue bias on the high voltage block .
it has focus and bias for all three colors
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
Mitsubishi tv problem
im assumiong you checked the tint in the menu options. if not go check it. other wise it sounds like you have a weak tube, or you do not know how to adjust the screen brightness. this is how i adjust the brightness (you dont need to touch the focus). turn the red up until your whole screen is tinted red, then do the same with the blue and the green. then go through each one and turn down just a little till your pic darkens a little. good luck
Sep 27, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WT-42313 color problem
see if this helps you out
http://www.digitalhome.ca/forum/showthread.php?t=21847
Dec 03, 2007 | Mitsubishi WT-42313 42" Rear Projection...
Green hot
Locate green screen control found behind speaker grill cover
and access panel lower front of tv......turn green screen ONLY
CCW a little.................T.
Oct 23, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Green color/tint over the display
yea you have to call a tech to make repairs to your tv it is having problem in the color circuit good luck
Apr 08, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
