SCMS-T blocks Bluetooth pairing with headset
I cannot pair my Motorola headset with my Toshiba laptop. It complains about the SCMS-T Copy Protection Settings. How do I fix this so that I can connect my headset to my laptop?
  • dipesh_k Dec 06, 2008
    I have HP TouchSmart desktop and running into same problem...Please help
  • d_magania May 11, 2010
    WWWOWOOOOOOOWWWWWWW
    suuuuuperrr!!!!!!
    that´s great.......
    simply fantastic.... i never imagine that my toshiba can operate Bluetooth sound and mouse together...... i´m so hapy...!!!! thanks a lot...
    Problem Solver:
  • 3 Answers
I would like to add that to get to the registry editor you will need to type regedit in the run menu.
Once there follow the instructional map above ie. before each \ there is a folder, keep opening the folders until you come to the ] when you are in that folder follow instructions below. (Remember the two folders your are adding to are the EZC and AV)
Next from the top Edit menu select New DWORD Value. Rename it what is written between the " "
ie. ShowAvContentProtectionMenu
Then left click and Modify and enter the numbers after the =dword: in the value data
ie. 00000001
click OK.
And repeat the process for the second instructional map.
It worked for me without a hitch, I hope you have the same success.
Posted on Jan 29, 2009
OMG you don't what I've been through.. thank you so much. You are my hero! Oh, and I might add that with windows 7 I had to login as administrator otherwise the regedit wouldn't stick.
Posted on Jan 06, 2010
  • wwlvictoria
    wwlvictoria Nov 20, 2016
    Great device, works very well the only issue, I received it 10 days late.
    if you want to get one ,please refer to:https://www.amazon.com/Charm-sonic-Bluet...
I can add to this that it also works flawlessly on the latest Bluetooth Stack from Toshiba v7.00.10 (see also http://aps2.toshiba-tro.de/bluetooth/?page=download) running on Windows 7! Before that I was running Vista with this headset (a Motorola HT820) in stereo mode and it worked OK, but after installing Windows 7, it was very frustrating to see this functionality having been disabled, so I was very pleased with this solution...
Posted on Nov 16, 2009
Add registry
-------------- SCMS-T.REG ---------------
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Toshiba\BluetoothStack \V1.0\EZC]
"ShowAvContentProtectionMenu"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\Toshiba\BluetoothStack \V1.0\AV]
"NoHeader"=dword:00000001
Posted on Oct 17, 2008
  • Laura Ferraria Aug 02, 2013
    Thanks. Helped a bunch!
H70 cant connect with my dell laptop it worked good yesterday maybe I removed something or changed setting
Disable and tenable Bluetooth. Clear past history. Put headset in pairing mode then use computer to search.
mark
motorola support
Aug 31, 2014 | Motorola Mobility H730 Bluetooth Headset
Bluetooth pairs but will not connect
Try pairing and connecting with another headset. Or delete the pairing and pair again.
Mark
Motorola Support
Aug 21, 2014 | Motorola Mobility Hx550 Bluetooth Headset...
Pair motorola 550 bluetooth to Iphone
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF,
then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
User Manual
You can obtain a copy of your user manual by locating the FCCID on the label directly on the device,
then then going to the FCC Website - https://fjallfoss.fcc.gov/oetcf/eas/reports/GenericSearch.cfm
Be sure to put the first three characters in the first box and the rest (including hyphens) in the second box.
Aug 30, 2009 | Motorola Mobility Bluetooth Hands Free...
Can't pair Motorola H375 wireless headset to my Toshiba A200-AH7
turn off headset
then press on hold on button untill the light stays on then run your blustooth.
hope this helped
Mar 14, 2009 | Motorola Mobility H300 Wireless Headset
Help pairing my H12 bluetooth
I successfully paired my bluetooth by going into the connection phase, just using my common sense on what to do next once I turned the bluetooth on. Since it was not paired to anything, it automatically went into pairing mode. Thanks anyway!
Dec 29, 2008 | Motorola Mobility Motopure H12 Bluetooth...
Pairing LG VX8700 with Motorola H700
try to power cycle the cellphone by turning it off and remove battery, then reinstall and turn it back on
For headset pairing
How to pair the phone with a Bluetooth™ headset The phone identifies and maintains up to 16 devices which are displayed in a list. To add a new device or pair a headset via bluetooth, turn Bluetooth™ on in both devices.
  1. Put headset in pairing mode. See Headset User Guide for more information, if needed.
  2. Turn on Bluetooth in your phone, Go to menu, [SETTINGS] > [CONNECTIVITY] > [BLUETOOTH] and press "Select"
  3. Choose [TURN ON] , press "Select"
  4. Choose [MY DEVICES], press "Select"
  5. Choose [NEW DEVICE], press "Select"
  6. Choose the headset to be paired and press ' Select '
  7. Enter the pass key '0000', press "Ok"
Link for headset setting, just choose the headset model
http://www.sonyericsson.com/cws/support/products/pairinginstructions/w300i?cc=us&lc=en
If you are using a different device the just set the Bluetooth to on on it as well
Apr 22, 2008 | Motorola Mobility H700 Headset
Bluetooth to mobile pairing
Push and hold both vol(+) and vol (-) at the same time for approx 2 secs. The headset will falsh green and red lights. Get your phone to search for bluetooth devices. It should find the headset. Enter pairing code 1234 in phone. Done
Jan 05, 2008 | OEM Systems Bluetooth Headsets - Model...
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Computers & Internet Logo
5,069 people viewed this question
David Payne
David Payne
