Question about Brother MFC 210C All-In-One InkJet Printer
Brother 420cn printer
How do i change or clean the waste tank?
Thank you
Need phone number
Posted on Apr 21, 2008
  • 832 Answers
You cant clean the ink absorber box. Go see www.brother.com and choose a service partner next your home. Buy a box as a spare part.
see pics how to open printer:
http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c
(use google translation; language is german)
Search fixya for error 46 or unable to clean on how to reset the eeprom.
Posted on Apr 13, 2008
Brothe mfc-j430w ink absorber full
Have a look at this link below. Try the purge count reset first and if that works have a look at cleaning out the waste chamber inside the machine. You must remove the casing and waste bottle, clean and refit the pads, and re-assemble the machine. It is a slow and messy procedure. It may be simpler and cheaper to just replace the machine.
http://resetmenow.blogspot.co.nz/2013/09/printer-reset-brother-mfc-j265w-and-mfc.html
Dec 12, 2014 | Brother MFC 420CN All-In-One InkJet...
My printer won't print anymore,it just stopped printing out of nowhere. When I try to print it just says unable to clean/print, refer to trouble shooting and routine matinance chapter in users manual. I...
If you look at the Brother website you will find a trouble shooting guide for your machine.
In the guide, for the error you quote Brothers guidance is to check for a stuck piece paper, however it also states that if the printhead is hard over to one side (righthand side if memory serves me correct), then to contact Brother. If you do so, Brother will tell you it needs to be serviced by a Brother agent, which will likely cost you more than a new one !
If it isnt a stuck piece of paper, the problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Aug 02, 2010 | Brother MFC 420CN All-In-One InkJet...
I have a brother mfc-420cn. I am getting a unable to clean messa
Do you mean "unable to clean"?If it this follow this instruction.
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If numberis over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Nov 02, 2009 | Brother MFC 420CN All-In-One InkJet...
Mirror images after downloading drivers
Dear Sir,
It seems to be problem with printer not with your leopard.
so follow these steps
1.check your printer catridge,make sure that ink is full.
2.If printer catridge is good then align printer catridges,you can find alignment option in in printer setting or properties page.
3.If above mentioned steps not solves your problem then may be your printer ink waste tank is full....you may need to replace waste tank,if your printer is new there is no question of waste tank.
i think it helps
if you find any difficulty leave a feedback regarding this issue,we will glad to assist you.
Have a nice day!
good luck
Sep 12, 2009 | Brother MFC 420CN All-In-One InkJet...
Printer que " unable to clean see troubleshooting in manual"
Unable to clean usually means the waste ink tank is full, the only repair is to replace the tank, aprox. $10.00 and reset the counter to clear the error. If you clear the error without a new tank you risk ink overflow inside the machine and on your table...
Aug 19, 2009 | Brother MFC 420CN All-In-One InkJet...
Unable to clean error message can selext "all or Color after hitting ink button
This is very common on Brother MFCs - they self clean excessively and when they've done a set number of self-cleans, they refuse to print and give the error message you quote.
There is a work around - you can reset the self-clean counter - but this carries a small risk the waste ink from cleaning that is normally stored insde the machine in a tank/sponge MAY leak out. I've done the work around on my Brother MFC and, so far, no leakage so if I were you I'd take a punt.
Just Google "brother mfc unable to clean" and somewhere in the results will be how to reset the counter - it's all done from the keyboard so no tools required.
Aug 16, 2009 | Brother MFC 420CN All-In-One InkJet...
Is there a waste ink absorber on a Brother MFC 420CN?
MFC420CN waste ink absorber how do you replace it or clean it ?
Dec 18, 2008 | Brother MFC-9420CN All-In-One Laser...
Unable to Clean - Code46
it could be a faulty printhead, the broter printheads has a warranty of 3 years, log a call with a brother warranty repair centre
Apr 23, 2008 | Brother MFC 210C All-In-One InkJet Printer
Cleaning
The waistinktank is full and has to be changed. Buy a new one from a service partner. Dont clean the old one, cause the felt will be as stone afterwards and wont take up any ink! See link how to open printer: http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c See here how to do the resetcode procedure: http://www.fixya.com/support/t139675-need_reset_purge_counter_due_error_46
Sep 18, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
207 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
