Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
When I make coffee, there is water leaking probably from the drain, even after I changed the seals with new ones.
  • Anonymous May 07, 2008
    water is leaking & is UNDER the coffee machine. I have tried to clean out everything & look to see where a leak may be coming from & have not found any blockage, etc yet. What should I try next? P.S. I have had my machine for 7 years now & still LOVE it! I have had 2 family members & 1 friend buy one after seeing mine- it's the best! (just need to fix this leak!)
  • 487 Answers
There are several places where this machine can leak. Check all the connecting hoses from the boiler , they are just clicked in by holder pins.
Even the seal in the boiler itself can be worn.
Follow this link for diagram and parts ( unfortunately in spanish sorry for that)
SAECO VIENNA SA
Oh by the way the seal on the spout which goes into your brew group can be damaged too. Check that first
Posted on May 11, 2008
Spins slow, does not drain and leaks a little.
SOUNDS LIKE MIGHT BE SEAL LEAKING WILL NEED TO DO BEIRINGS AND SEALS
Jun 17, 2012 | Maytag LAT2300 Top Load Washer
When pulling coffee by opening valve, water leaks from spindle. Safety valve is leaking?
in the system you have 2 safety valves. one for tank other for coffee boiler. the coffee boiler safety valve should be set at 12 bar. if safety valve of boiler is leaking try resetting or changing rubber than setting.
ps: do not touch the tank safety valve, only change it with new, tested and sealed one.
Feb 09, 2011 | La Pavoni CUA001R Cuadra Espresso Machine
My Krups espresso 7260 is not producing full shots and water comes out under the machine each time I pull a shot or make a (not so) long coffee. Help!
if the machine is old it could be leaking due to lime/calcium build up limeaway and clr should fix the problem, if not you probably have a cracked hose inside
Jan 12, 2011 | Krups XP7260 Espresso Machine
Brand new Mr coffee PSTX series coffee maker leaks water from the base while fluid level in reservoir drops even before the brew cycle is turned on. I have double checked the seating of the reservior but...
If you look where the reservior fits into the base, specifically where the water goes in, there is a rubber seal. It's held in by a circulary plastic piece and 3 screws. I took it apart there to see if something was amiss and decided after looking at it some that they had put the seal in upside down. So I put it back together with the lip of the seal facing up instead of down and I have not had a single drop of water leak from the reservior again. Now if I can get the thermos pot that came with it to stop leaking every time I pour a cup I will be a happy camper.
Aug 28, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
I have had my Bunn for 5 years and have loved the convenience of the 3 minute coffee, plus the coffee is always great, but for the last 6-8 months it has been leaking from the bottom. I go to work very...
Most likely the problem is in the water intake area. I have the same problem, I took my machine apart, removing the top revealed a plastic water chamber which leads to a connector that lets the water go into the heating chamber. The seal had become brittle, and the plastic water chamber also was degenerating where it met the heated water chamber. I replaced the rubber seal and that worked the first time, however, I think the plastic has now deteriorated to the point that I will need a new reservoir piece and a new seal. It's probably time to send in the unit for repair.
I think one repair for a 25-30 year old coffee maker sin't such a bad deal!
Feb 14, 2010 | Bunn NHB Coffee Maker
Bottom of dishwasher leaks even after the last rinse water has been drained
If it is the bottom then look at rubber seals and gaskets which can be replaced. If it is not that then probably rusted through and time for a new unit. Also feel around hoses to see if water indicates a loose clamp on a hose or a leak in one.
Make sure it is not the bottom of the rubber seals on door which is relatively cheap too replace through manufacturer.
May 09, 2009 | Danby DDW1805W Designer Series...
Resover leaking
The easy fix for leaking under the machine is check to see if the drain is clogged. Open the front and remove the brew unit. You will see a small hole that will drain the excess into the Plastic tray. Usualy I find Coffee grounds clogging the drain hole. Use Pipe Cleaner , Q-Tip to clear the drain hole. you can also wipe out from the other side with paper towel or Q-tips. once the clog is clear. Flush our with water.
Feb 24, 2009 | Saeco Vienna SuperAutomatica Coffee...
COFFEE MAKER LEAKS CLEAR WATER FROM THE BOTTOM EVERY TIME I USE T
Have the same issue, looking for my receipt for warranty. All of us having this problem can't be wrong and it must be defective
Dec 30, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Water leakage- V'spresso machine
I had the same problem. The water was coming from the front door switch inside top right. I followed the water and turns out the part that needed to be replaced was the steam valve body. #48. http://www.shop.partsguru.com/images/1208344975339-771025787.jpeg and link http://www.shop.partsguru.com/images/1208344975339-771025787.jpeg after I changed it the pool of water under the machine stopped. I hope this helps.
Jan 29, 2008 | Saeco V-spresso Espresso Machine
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
123 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
