Question about Tomtom One Europe v2 GPS Receiver
Tomtom problem working normal
Ever since i connected it to the computer it hasn't been turning on. This is what I did:
I plugged it into my computer via USB and then installed the program. I think windows installed a driver for it.
Then I tried putting safety cameras on it but then didn't bother with it and unplugged the tom tom from the computer. I then Turned it on and it shoes a image like this one here
http://www.tomtom.com/lib/img/cs/654_02....
when i turn it on, a thing shows when the card is being pulled out of the tom tom then a cross it being draw on it like the one in the image above ^
I have tried resetting it several times and then it make the memory card (SD) coded and when i read the files on thew computer they have a strange code on them and i don't understand it. the files are all 0kb and when i try opening them it says it could not read from disk.
After that i formatted the memory card and put on 1 voice and 1 map using the tom tom home program. And now i don't know what to do. Please help I'm desperate plus it's not even mine. :help: :help:
This link to the TomTom site refers to your prob. Haven't read thru' it but maybe it's the solution.
http://www.tomtom.com/support/product.php?ID=1679&Language=4&query=red+x&FID=6363
Posted on May 05, 2008
When i turn my tomtom on i only see tomtom anf symbol
If it doesn't continue to show the license and owner screen, it means that the TomTom (navigation) software is not running properly. Often it means that the software is corrupt, and it has to be repaired or replaced.
If you are able to connect the TomTom device to a computer (using the USB port), select the TomTom disk, right click and select Properties, and run the TOOLs to check and repair the (TomTom) disk. After completing the repair, disconnect it (from the computer), restart the TomTom - turn it off and turn it back on, and see if you get it going normally. If not, you'll need to restore your navigation software from your backup and see if it works. Or you can download the navigation software from the TomTom website and copy it onto your GPS device.
Aug 08, 2014 | Tomtom XXL GPS
I reformated my canada xl 310.i lost all my files.just a screen with a red x.
You've probably backed up the contents of your TomTom disk (when it was connected to your computer) to your computer before you reformatted the TomTom Disk. Or you used the TomTom Home to back up the contents of your TomTom.
Try to copy the back-up files back on to your TomTom device disk and see if it works.
Just curious ... why did you reformat your TomTom disk ? which will erase all the files on the TomTom disk.
Jan 25, 2014 | Tomtom XL GPS
The tomtom device prompts me to connect the traffic receiver.How do I do that
This is for the RDS-TMC antenna.
Plug the end fitting on the antenna into the bottom of the Tom Tom. Plug your normal power cable into the antenna.
If it's working, when you turn it on, you should see a new display, narrow, vertical, on the far-right side of the screen.
Oct 30, 2009 | Tomtom Tom Tom RDS-TMC Traffic Receiver...
I have connected to my computer but nothing happens.
I presume that you are using the docking unit, so plug it into a usb with the tomtom turned off, then when you turn it on it should boot up the tomtom home prog.
If that doesn't work, remove any existing tomtom home prog from your PC and try again.
Download tomtom home from your CD or from the website.
If you have aquired the unit second hand it may be blocked due to security reasons.
The only way to sort it then is to mail TomTom and give them your serial number and an explanation !
Apr 23, 2009 | Tomtom GO GPS Receiver
Tomtom GO 720 won't connect to tomtom home
hold the reset button in for 15 seconds located on the botton of the tomtom,plug in the usb then the tom tom and turn on this should slove your problem
Feb 12, 2009 | Tomtom GO 720 GPS Receiver
Tomtom will not turn on.
I had this problem with a TomTom ONE LE model.
There are a few things you should do before you decide to toss it or get another one.
Are you able to connect it to your computer via USB? Does it show that the device has been connected? If so, you can try to format the device and reinstall the software via TomTom HOME software.
Have you tried the device with another power cord? Sometimes the car charger gets fried and causes devices to shut off at weird random times, or to never turn on.
If you can't connect to the computer and a proven working car charger won't work with your device, try calling TomTom customer service.
Oct 15, 2008 | Tomtom ONE GPS Receiver
Tom tom not working
  1. First , try a re-set through the 'reset' hole underneath the tomtom. 1 quick short press is all thats required. Unlike others suggest , you do not need to hold it in for anything longer than half a second. You should feel the switch 'click' as its a tactile switch. Don't press too hard as you can damage the switch and cause it to lock ON. Once pressed , try turning the tomtom on as normal. Sometimes a tomtom battery can drop below its normal "shelf" voltage ( normal is about 3.8 volts ). A tomtom charger has a protection circuit inside to stop or slow the current it gives out if there is a short. If your battery HAS dropped volts TOO MUCH ( less than 3 volts ) the charger can "see" the tomtom battery as a "short" and the charger therefore shuts down and doesnt charge the battery. You could leave the charger connected and HOPE that the very small amount of current it's putting out will eventualy bring the battery up over 3 volts. Once it is up near its "shelf" voltage ( called shelf voltage as that is the voltage the battery is at 'on the shelf' ie . when its not powering anything ) the charger will begin to charge as normal....... OR ... you can gain access to the battery and charge it from a bench power supply that has voltage and current meters. Once again , once the battery voltage gets something near 3.8 volts the normal tomtom charger can be used to charge it. You caould connect another normal battery to the tomtom battery just for a few seconds ( not recommended and can be a bit dangerous ) if the normal battery is such as a PP3 9v type it should bring up the tomtom battery to over 3.8 volts in a few seconds. The tomtom can then be charged as normal. .............. It is also possible that some internal IC's ( chips ) have blown inside the tomtom and unfortunatly this would require a specialist repair centre to replace them as they are really very very small and are not a normal soldering job. Good luck. ... if this post has helped you or interested you please rate the author.
Jan 12, 2008 | Tomtom ONE GPS Receiver
TomTom 520 won't start
Hi all,
I got the following response to this little problem. Will try it out and hopefully my 520 will work again soon.
To ensure that your device is correctly connected to your PC, please do the following:-
STEP 1 Run the Registry Cleaner Tool
• Disconnect the TomTom and remove any USB devices from your PC, If you use a USB Hub, please disconnect that also.
• Run the RemoveRegEntries tool. You can download it from :-http://tomtom.com/lib/img/cs/S4S/files/RemoveRegEntries_TTGOv1.exe
A Black window will appear briefly then close.
• Make sure that you have got Administrator rights on the PC. Otherwise you may not be allowed to connect new hardware (especially the case when using office computers)
• Reboot your PC
STEP 2 Connect the TomTom
• Make sure the device is fully charged before connecting it to the computer. Ideally a mininum of 4 hours charge.
• Reset the device using a paper clip (see http://www.tomtom.com/6965). When resetting, keep the reset button pushed in for at least 20 seconds, but DO NOT turn the device back on just yet.
• Ensure that your TomTom has power connected to it. There should be a green light on the TomTom unit. If your device came with a Home Charger, please make sure that is plugged in to the TomTom also.
• Connect the TomTom to a USB port on the back of your PC. We strongly suggest that you use a USB 2.0 port and not a USB 1.1 Port. (USB 2.0 ports are faster USB ports, which are standard on all modern PC's, older PC's and some laptops may still use USB 1.1 ports which are slower and can prevent some USB devices from connecting properly).
STEP 3 Switch the TomTom On.
• On your PC, open My Computer
• Now switch the TomTom On while it is connected to the PC with the green light on.
• Look at My Computer, do any disk drives appear as you switch the TomTom On? If so, which drive letter is it?
• Double click on the TomTom disk.
• What files and yellow folders do you see?, please make a note of them and reply back with what files and yellow folders you see. If possible, please provide us with a screenshot showing all the details.
If the device is NOT listed as a 'Removable drive' under 'My Computer' when you switch the TomTom On, try the following:-
STEP 4 Check Device Manager
• Disconnect the TomTom from the computer.
• It is likely that you have a Firewall on your PC, in some cases, Firewalls can prevent USB devices from being recognized by the PC. We suggest configuring your Firewall and security settings to allow all USB devices to connect to your PC. Once you have done this, we suggest trying the steps above again.
• Go to 'Start' and right-click on 'My Computer' and select 'Properties'
• Select the 'Hardware' tab
• Expand 'Disk drives'. If the TomTom device is shown there with a red cross, right-click on it and select 'Enable'
• Check under 'My Computer' to see if the device now shows up as a 'Removable drive'.
We also suggest it is a good idea to try to connect your TomTom to another PC to see if you get the same problem.
Dec 27, 2007 | Tomtom GO 910 GPS Receiver
Tomtom One Europe v2 GPS Receiver Logo
110 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
