Question about GE GSL25JFPBS Side by Side Refrigerator
Ge side by side refrigerator model #gsl25jfpbs
My fridge seems to run a lot. is ther something i can clean and not have it run all the time
    Genius:
  • 1,073 Answers
Clean the condenser coil, the one on the bottom. that is a bout it , should help unless you have some other issue in the machine
Posted on Apr 12, 2008
Adjustment temperture on ge side by side model gss25gfxaww
You can't adjust it. You can set a new set point and see if it gets there in 24 hours, otherwise you might have a problem with you fridge.
Jul 25, 2012 | GE GSL25JFPBS Side by Side Refrigerator
Serious heating of fridge PCG21IBS
Make sure the venting inside isn't blocked. I would have an appliance repairman service it. Most likely it's something more deeply involved.
Apr 29, 2012 | GE GSL25JFPBS Side by Side Refrigerator
I have frost on the freezer side and both the freezer and fridge are not keeping the food / frozen items cold. The fridge seems to be running constantly
remove the rear panel in the freezer,and if evaporator coils a solid block of ice,take a hand held hair dryer and melt the ice,then remove the heater located under the coil and test it for continuity,if open replace it with g.e.# wr51x10055 heater element
Aug 07, 2011 | GE GSL25JFPBS Side by Side Refrigerator
The freezer compartment of GE GSL25JFPBS Side by Side Refrigerator is icing up at the buttom.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | GE GSL25JFPBS Side by Side Refrigerator
How to make me ge 29.8cu.ft. be more energy efficent. it is a older model.it is a profile tfh30pr. it seems it runs a lot.
If your fridge seems to be running a lot more than normal, it is likely because the heat dissipation coils are clogged with dust. Most likely they are located on the bottom of fridge.
There should be a removable kick plate under the door. Often just snaps in.
Remove kick plate and use a vacuum hose to vac out the dust bunnies.
At your local hardware store you should be able to buy cheaply a long skinny brush to reach between coils and clean out.
You should pull the whole fridge out and get it from back also.
This will increase the efficiency on your fridge.
If you notice no change at all, or if you've done this already, it's possible the fridge has a problem.
Nov 27, 2010 | GE Profile Performance 29.8 cu. ft....
Motor runs, but freezer and fridge are warm
The cooling coil/evaporator might not be defrosting.
This could be caused by a defective defrost timer or the defrost heater is not working. Also make sure it is clean underneath the refrigerator and the condenser fan next to the coil in running
Oct 10, 2009 | GE GSL25JFPBS Side by Side Refrigerator
GE GSL25JFPBS Side by Side Refrigerator Logo
238 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
