Question about Autotek MX3000.1 Car Audio Amplifier
Wire Identity I have an older autotek amp model AT7150. I need to identify speaker wire locations and color on amplifier. It has a wiring harness for the speaker wires I just don't know what color is for what. Please help.
  • 631 Answers
If the plug is like the BTS series amps...
Image of connector on amplifier
Posted on Apr 13, 2008
2000 jeep grand cherokee wiring diagram
You have to cut the factory speaker wires on both sides of the amp and solder them together.(bypass the amp) Pull out the factory radio so you can identify the color of the speaker wires or look at the wire colors on the back of the factory speakers.
Dec 09, 2013 | Car Audio & Video
Need to know the color of each speaker wire on the speaker factory harness
1995 Ford Explorer Car Stereo Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Jun 27, 2012 | 1995 Ford Explorer
Need a wiring diagram for 2002 chev, caviler stereo hooking up aftermarket stereo
ARE YOU AWARE THEY MAKE A VERY INEXPENSIVE ADAPTER HARNESS THAT HOOKS UP TO THE FACTORY HARNESS, NO WIRE CUTING,CAR AUDIO SHOP CAN GET THE ONE U NEED, ABOUT $12. HERE IS THE WIRING COLOR BREAKDOWN OF THE DASH HARNESS.
2002 Chevrolet Cavalier Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Ignition Switch (The radio harness does not provide a switched power source. Run a wire from the Ignition Switch.)
Car Radio Illumination Wire: Gray
Car Stereo Antenna Trigger: Pink
Car Stereo Amp Trigger Wire: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 13, 2010 | 2002 Chevrolet Cavalier Coupe
What colors go to what colors of the stock wiering
If your car does not have an amp. use this wiring harness
Metra Electronics Corp. 70-5600
FORD Ranger/Explorer 1995-Up - Into Car. I f you car has amp. you need this one Metra Electronics Corp. 70-5603
Factory amplifier integration harness. I recomend you to by one of this wiring harnes is easy for you.
1998 Lincoln Navigator Car Stereo Wiring Diagram
Radio Battery Constant 12v+ Wire: White/Violet
Radio Accessory Switched 12v+ Wire: Black/Pink
Radio Ground Wire: Black/Green
Radio Illumination Wire: Blue/Black
Car Stereo Antenna Trigger Wire: Yellow/Red
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Red
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): White/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Blue/Black
Right Rear Speaker Positive Wire (+): Violet/White
Jan 16, 2010 | Car Audio & Video
Parrot to GMC Sierra setup.
here,
When I did this truck I had to go to the amp under the center console. Good luck
#510564: 2007 GMC SIERRA C1500 2DR TRUCK
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery ORANGE (+) RADIO HARNESS
Accesory (CLASS 2 DATA) (+) RADIO HARNESS
THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE. RUN A WIRE TO THE FUSEBOX FOR SWITCHED POWER. THE ACCESSORY TURN-ON AND AMPLIFIER TURN-ON ARE CONTROLLED BY THE CLASS 2 SERIAL NETWORK.
Ground BLACK/WHITE (-) RADIO HARNESS
Illumination GRAY (+) RADIO HARNESS
Dimmer BROWN (+) RADIO HARNESS
Amp Turn On PINK (+) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) GRAY
RF Speaker (+) LIGHT GREEN
RF Speaker (-) DARK GREEN
LR Speaker (+) BROWN
LR Speaker (-) YELLOW
RR Speaker (+) DARK BLUE
RR Speaker (-) LIGHT BLUE
Amp Location UNDER CENTER CONSOLE
Steering Cntrls OPTIONAL
THIS VEHICLE MAY BE EQUIPPED WITH OPTIONAL ONSTAR® TELEMATICS EQUIPMENT. USE AN APPROPRIATE INTEGRATION HARNESS OR INSTALLATION PROCEDURE TO ENSURE PROPER FUNCTION OF THIS EQUIPMENT.
Speed Cntrl OPTIONAL
Radio Security YES
Jan 08, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Autotek Bass Thrust 44 Wiring
thin blue wire is the remote wire and goes to the deck remote line
large diam wire goes to battery
large diam "black" goes to ground
rca ... wires with the metal ends plug into the white and red holes
you have two sets of speaker wire comming off the amp also
hope this helps
Dec 11, 2008 | Car Audio & Video
Aplifier gettieng protection signal and excess heat
for that amplifier, it is recommended that you are driving a 4 ohm load. It can drive a 2 ohm load, but will produce more heat and shorten the life of the amplifier. Is the subwoofer a single or dual voice coil? You'll want to make sure that you're not running below a 2 ohm load or you'll always go into protection. Also, try disconnecting the speaker wire completely from the amp so nothing but power is connected. If the amplifier is still in protection mode when no speakers are hooked up, then the amp is bad and will need repair or replacement.
Sep 28, 2008 | Autotek Car Audio & Video
Autotek 7100 BTS series
99% of pots are off the shelf items.
See a tech with a parts catalog and a soldering iron.
Labor will far out price, the part.
Experience ain't cheap.
Regards, Sumthin
Jun 10, 2008 | Autotek MX3000.1 Car Audio Amplifier
Need information
This plug configuration should be the same as the old autotek. The wires on the sides of the remote are the positive speaker wires. With the amp orientated so that the 3 wires are on top, the wire left of the remote on the amp plug should be the left positive. The one directly under it is the negative for that channel. The ones to the right are the right channel (negative on bottom again).
You can confirm left/right after you get the amp powered up. Drive signal into one RCA jack at a time and check for output on the corresponding speaker wires.
Apr 12, 2008 | Car Audio & Video
Autotek MX3000.1 Car Audio Amplifier Logo
322 people viewed this question
Top Autotek Car Audio & Video Experts
kli99gunrunn
Tom Chichester
FastHarley
FastHarley
Are you an Autotek Car Audio and Video Expert? Answer questions, earn points and help others
