When I turn on the washing machine (Indesit Widl 102) all the lights at the top and the on/off button and the door lock button and the dryer button (last in the line of 4 buttons) all flash very quickly simultaneously. I have cleaned out the filter and it is still happening. The machine wont turn on or off and I cant use it on any programme setting. I have tried unplugging it for long periods of time but it doesn't help. It is only 3 years old and I rarely use the dryer.
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and/or its panel that is going bad. To start with check the Thermal fuse which is mounted to the exhaust duct inside the back cover panel. Please do accept the solution if the issue is resolved or post a comment with a more detailed question including the manufacturers name and model no# for your dryer so that I can further assist you.
Thanks
Rylee
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
