Question about SanDisk Sansa e260 MP3 Player
Trying to recover my sansa 4gb
Everytime i go to the Sandisk website to download the recovery tool it wont let me, it keeps on asking about a jit or something
  • 8,596 Answers
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Posted on May 23, 2008
My Sansa Disk don't turn on
Run the recovery tool from the SanDisk website .
Download Sansa Disk Recovery tool
How to use Sansa Recovery tool(instructions)
Download Adobe reader
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Mar 21, 2011 | SanDisk Audio Players & Recorders
Empty sansa 4gb mp3, no software on device
How to use the Sansa Recovery Tool for Sans Connect:
http://kb.sandisk.com/app/answers/detail/a_id/863/kw/RECOVERY/r_id/101834
Check
2 things to check before starting the Recovery Mode and to use the Recovery Tool:
- First, charge the Sansa Connect for at least 20 minutes using the AC charger to ensure this is not a battery depletion problem.
- Second, hold the power button for 8-10 seconds to ensure the device is turned OFF.
After these steps, you can put the Sansa Connect into Recovery Mode and use the Recovery Tool.
direct to the download Sansa Recovery Tool [66 MB]
direct to the download How To pdf file [420 kB]
Sep 22, 2009 | SanDisk Sansa Connect MP3 Player
Wont connect
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 26, 2008 | SanDisk Sansa Clip MP3 Player
Computer will not dispay sandisk, mp3 player will not go past sandisk screen
Reset the player first. If it keeps going to that screen, try a different usb port. Then download the Sansa Recovery Tool from the Sandisk website. If Recovery fails to resolve, then do a firmware upgrade.
-Tha Mp3 Doctor
Jun 26, 2008 | SanDisk Audio Players & Recorders
HELP WITH SANSA E260
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
Best of Luck.
Nov 02, 2007 | SanDisk Sansa e200 MP3 Player
Flashing screen
Try this;
Best of Luck.
Oct 29, 2007 | SanDisk Sansa e250 MP3 Player
My sansa e280 rhapsody says switch to recovery mode
Recovery mode is used to recover from a fatal error.
Follow these steps and youll be back in business.
Best of Luck.
Oct 22, 2007 | SanDisk Sansa e260 MP3 Player
Wont start!!
This will take care of it.
Best of Luck.
Oct 15, 2007 | SanDisk Sansa e260 MP3 Player
Sansa media player 4gb
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Oct 02, 2007 | SanDisk Sansa e250 MP3 Player
It wont turn on
Oct 01, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
53 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
