Not working, flashing lights 1, water checked, hose checked, door clicked properly, sounds as though trying to pump water, nothing happening.
Pull the machine out and tip it carefully to one side, if water comes out from the base then the problem is the union on the upper feed pipe. Remove the top inner dish rack and twist the star shaped nut clockwise gently! Make sure you have got as much of the water out as possible, stand the unit back up and turn put it into cycle.
Just installed Indesit Di 450. Flashing lights 2 - 4? Any ideas?
Salt is full and never been used.
Thanks in advance
THANKS. We eventually called out an engineer and they said the hose had been smashed off, now have a new one which works!!!!
indesit dishwasher 1 yr old not pumping out water have checked filters hose all clear any suggestions would be appreciated.
thanks babs
THE MACHINE HAS NO WATER INSIDE AND DRAINS IF I PUT ANY IN
