Question about Car Audio & Video
Need information I need to identify speaker wires on my amplifier. It is an older amp that was given to me.
  • Anonymous Apr 13, 2008
    HELLO I WAS GIVEN A OLD HIFONICS JUPITER VII 140 WATT FOUR CHANNEL MOS---FET AMP SEEMS IN GOOD CONDITION IT HAS 1 PLUG THAT CAME WITH IT AND I BOUGHT ANOTHER 1 AT RADIO SHACK THE 1 THAT CAME WITH HAS 3 WIRES ON TOP ROW --PURPLE ORANGE AND BROWN IT SAYS USE EITHER ORANGE FOR TURN ON ON THE AMP
    THE BOTTOM HAS 2 GREEN UNDER THE PURPLE AND GREY UNDER THE BROWN
    I NEED TO KNOW WHICH IS POSITIVE AND NEGATIVE AND RIGHT AND LEFT SIDE I PLAN ON USING THIS AMP FOR MY 10" SUBS I WANT THE MOST POWER HOW SHOULD I WIRE IT THANK-YOU
  • 631 Answers
This plug configuration should be the same as the old autotek. The wires on the sides of the remote are the positive speaker wires. With the amp orientated so that the 3 wires are on top, the wire left of the remote on the amp plug should be the left positive. The one directly under it is the negative for that channel. The ones to the right are the right channel (negative on bottom again).
You can confirm left/right after you get the amp powered up. Drive signal into one RCA jack at a time and check for output on the corresponding speaker wires.
Posted on Apr 17, 2008
No base in one speaker
Usually this is because the base driver in your speaker is shot. I have repaired hundreds of amplifiers and have never found just the BASS being low at the output of the amp. If the amp is working, then the likelyhood of the speaker being defective is good. A quick test is to just swap speakers and see if the problem moves to the other channel.
If you have a very old transistorized amplifier, you may have a large value coupling capacitor between the actual amplifier circuitry and the speaker output. This is because the older amps had a large DC voltage at the output of the amplifier and this had to be removed or the speaker would be damaged. This capacitor may have finally given up the ghost and needs replacing. While you are at it, you may as well replace both as the other is soon to go.
My bet is that the woofer in the speaker cabinet has blown.
May 09, 2014 | NAD C370 2-Channel Amplifier
2000 jeep grand cherokee wiring diagram
You have to cut the factory speaker wires on both sides of the amp and solder them together.(bypass the amp) Pull out the factory radio so you can identify the color of the speaker wires or look at the wire colors on the back of the factory speakers.
Dec 09, 2013 | Car Audio & Video
If you can help me i need to know if it is possible to wire a amp into a 2002 landcrusier stock headunit cheers
yes, there is an amp turn-on wire from the head unit (black with a red stripe). You will need to add a power wire and fuse from the fuse box to run the amp. You can use the speaker outputs as inputs to the amp, depending on what you are trying to do. Please let me know if you need more help, and identify the amp model as well as the speakers you will connect.
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Black/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Black/Red
Car Stereo Amplifier Location: Under the center console.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): Yellow
Aug 27, 2011 | Car Audio & Video
Car audio wiring color codes.for 1988 ford f150 truck
Thanks for using FixYa.
1988 Ford F150 Truck Car Radio Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Blue/Red
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Corners
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Jan 25, 2011 | Car Audio & Video
I need help to identify radio wiring
Is this what you needed?
1986 Toyota Celica Car Stereo Wiring Information
Car Radio Illumination Wire: Green
Car Stereo Antenna Trigger Wire: Black/Red
Car Audio Front Speakers Size: 4?
Car Audio Front Speakers Location: Dash
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Light Green
Car Audio Rear Speakers Size: 5 1/4?
Car Audio Rear Speakers Location: Side Shelves
Right Rear Speaker Negative Wire (-): White
Oct 25, 2010 | 1986 Toyota Celica
Need wiring diagram for Sony XM-E70 Equalizer/Amp
You need 1 thick ground cable ( usually brown)
you need 1 thick power cable ( same thickness and wire as ground usually red )
you should have 1 rem wire ( thin blue )
RCAs, 2 for sub, extra 2 for 2 speakers.
The rest I have no idea what they are.
You need speaker cables to sub or amp.
Some products use different colouring. Maybe the 9 pin connector is for head deck to speakers.
Jun 30, 2009 | Sony XM-SD61X Car Audio Amplifier
Amp has power but now sound
You have not given any information on your models. Chances are you wired them incorrectly. either the first time, or both times. How do you know you burned up the sub and not the amp? chances are the amp is fried, most likely due to wiring the speakers to the wrong impedance.
Nov 19, 2008 | Kicker Car Audio & Video
Ford taurus
HERE IT IS. PLEASE RATE ME.
2004 Ford Taurus Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Black
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: N/A
Car Stereo Antenna Trigger: N/A
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Tan/Green
Right Front Speaker Negative Wire (-): Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Blue
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Black/Violet
Right Rear Speaker Negative Wire (-): Orange/Violet
Nov 14, 2008 | 2000 Ford Taurus
Wiring Diagram for Sony car amplifier XM-554ZR
You can download the installation manual from the link below: http://www.sony.co.id/support/product/xm-554zr?site=hp_en_ID_i It has the following diagram plus other hookup info... Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 14, 2007 | Sony XM-2150GSX Car Audio Amplifier
Car Audio & Video Logo
69 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
