Question about Hitachi 53UDX10B 53" Rear Projection Television
PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
CONVERGENCE PROBLEM BLUE SHADOW ON HITACHI ULTRAVISION MODEL 53UWX10BA I CAN DO A MAGIC FOCUS BUT I GET A #4 AT THE END OF THE FOCUS. ONCE THE TV WARMS UP THE MAGIC FOCUS FINALLY WORKS AND THE TV LOOKS OK BUT WHEN I TURN IT ON IT HAS THE BLUE SHADOW UNTIL IT FINALLY WARMS UP
  • tmc 2008 Apr 25, 2008
    I bought the ICs and did the work myself and now my picture looks great. In order to do this project, you need to know how to solder ICs but I had not done much soldering before but found all the tutorials I needed on line. This was not an easy project, it took me about 3 hours to complete and the hardest part was getting the old ICs off of the heatsink, they were baked on good. I got my soldering iron and solder from Radio Shack. I used the de-braiding solder to remove the ICs and it worked great. I took pictures of my project and will make those available.
    I bought 2 sets of ICs (4 total) in case this happens again, plus the parts I bought at Radio shack(thermal grease, compressed air, solder ******) all came to about $80 total. The estimate for service was $100.00 just for a tech to come out and diagnose the problem and he said over the phone that is would probably be about $500 to fix it. He was a real nice guy and said since my set was 7 years old it may not be work fixing since the color gun could go next and that could be another $600.00. In addition, I would have to take my huge TV to a service shop! He recommended buying a new set since my set was older, so I canceled the service call and I decided to try the repair myself since if it did not work I would go buy a new set, but now it looks great! I also took the front off the set and cleaned the lenses and that really made it a much better more crisp picture. Basically, I feel like I just got a new TV for 80 bucks! It took about 4 days for the parts to show up and after a little practice soldering I just dove into the project. I am really excited that this worked!
  • shawn_40312 Feb 13, 2009
    Seems like i have the same type of problem. I have a red glare where there is black. Also, blue color doesnt work enough. Not sure if its the exact same issue or not.
  • 121 Answers
It sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
http://servicemanuals.vstore.ca/
Posted on Apr 13, 2008
I have a Hitachi 53UWX10BA tv. The picture colors are off and blurry. I ran magic focus and it showed a 4 on the bottom of the screen
Ur tv have a problems known as a convergence problems,it dead.Tv have corlors R,G,B lines mis alignments,have colors shadows picture or 3D picture look alike?Yes.The tv convergence board is dead.The convergence board must change 2 STK convergence ICS and some or all of it resistors to fix the convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Feb 28, 2011 | Hitachi Televison & Video
The top of the screen is yellow color then drops down in a swoop and more yellow and blue. otherwise picture is good, pushed the magic focus but it did no good. thanks for any help
The magic focus button don't work.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 15, 2010 | Hitachi 65TWX20B 65" Rear Projection...
Ultravision Digital TV has shadows and vertical
I believe it is either interference or a convergence issue. To fix an issue with convergence try to find a convergence setting in the menu. If thatr doesn't work try to clean your projection lenses with a q-tip and alcohol.
Good Luck.
Mar 14, 2010 | Televison & Video
I have a hitachi ultravision and the blue is off center.
your convergances amps ics have failed and need to be replaced alone with the 2 burnt resistors you will find then run magic focus
Nov 30, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UWX10BA HDTV with convergence problem for blue
No there are no quick fix options for this fault. The convergence amplifiers operate similar to a high power audio amplifier, so if there is an impairment anywhere in the system, it will result in distorted audio, or in the case of television convergence amplifiers, a color won't align. The convergence power pacs need to be replaced and the out of tolerance precision resistors located near the power pacs need to be carefully checked and replaced as necessary.
It is also possible that there are root faults that cause the amplifiers to go bad which include bad connections or a bad digital control module. This repair is possible for anyone having basic electronics knowledge and soldering skills.
Apr 28, 2009 | Hitachi 53UDX10B 53" Rear Projection...
I HAVE A HITACHI PROJECTION COLOR TV. MODEL 53UWX10BA 52". I JUST MOVED THE TV BY TRAILER FROM ONE TOWN TO ANOTHER, ABOUT 25 MILES, WHEN I PLUGGED THE TV BACK IN AND HOOKED UP THE CABLES, THE PICTURE WAS...
Replace the convergence Ic's with a kit that is available through your local parts distributor
You must replace all resistors in the kit
If you are not good at soldering and de- soldering have a local tv shop do it for you
Good luck
Jan 27, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 55inch projection tv with blue shadow.
Blue Convergence Ic is defective. let me know if you need to know where to get a replacement IC
May 04, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Green lines along top of Hitachi 53UWX10BA
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 02, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Problem in Hitachi 53UWX10BA
The convergence ic's, and related components that could'be affected need to be replaced cost to repair 250.00 2hrs job max with alignment this depending on the tech. If you need more help let me know
Jun 14, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
2,229 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
